Author Topic: [IC] Zodiac by Nyhxis | A stylish 12 key angled macropad  (Read 28519 times)
Offline Xonuss
« on: Mon, 14 November 2022, 15:13:45 »
Zodiac
by Nyhxis
Hello there.
I'd like to introduce to you the Zodiac macropad, a fully programmable 12 key angled macropad.
293270-0
IC Form
Full Render Gallery
Initial Prototype Gallery
Discord
What is it?
The Zodiac is a macropad that you can use for macros (naturally), shortcuts, easy accessibility to specific keys, functional artisan display, you name it.
Features
  • 2-piece construction made from 6063 aluminium
  • Hotswap sockets for easy assembly
  • QMK and VIA compatibility
  • Custom feet
  • USB-C port
Possible Color Variants
Blue
293272-1
Red
293274-2
Green
293276-3
Silver
293278-4
Black
293280-5
Pink
293282-6
Violet
293284-7
Any other color you'd prefer? Fill out the IC form and share your thougths!
Price
Price are still undetermined, but aiming at a €100 upper limit. A more definitive price should be possible as we proceed with the IC and gather more information on quantity.
Initial Prototype
293286-8293288-9
293290-10293292-11
What's changed since the prototype?
Modified the overall design a little bit:
  • Tightened the case slot, more aligned with the keycaps
  • Centered the USB port
  • Rounded the outer corners for a more pleasant look
  • The overall "extrusion" of the case
What's next?
  • Finish refinement of the design
  • Consider review units to send out
  • Consider possibilities of included keycaps
  • Consider molded feet, rather than diecut
  • Consider plate standoffs for easy reassembly, or an alternative
  • Consider other case materials, such as brass, stainless steel, PC, etc.
  • Consider final colors, and ano vs e-coating
Thank you for checking out this IC!
Do please consider adding this signature to your profile
297449-12
Code: [Select]
[url=https://geekhack.org/index.php?topic=118859][img]https://i.imgur.com/cVXzmPG.png[/img][/url]
« Last Edit: Mon, 13 March 2023, 16:24:07 by Xonuss »
Offline Xonuss
Re: [IC] Zodiac by Nyhxis | A stylish 12 key angled macropad
« Reply #1 on: Mon, 14 November 2022, 15:14:24 »
Reserved
Offline farlig
  • * St. Jude Supporter
« Reply #2 on: Mon, 14 November 2022, 16:55:35 »
Loving this, looking like I might finally pick up a premium macropad
Offline mr_foggy
  • neue = nope
« Reply #3 on: Tue, 15 November 2022, 09:48:26 »
same, looks like this is going to be my first macropad.
Offline Morbii
« Reply #4 on: Tue, 15 November 2022, 10:22:03 »
Looks nice
Offline Xonuss
« Reply #5 on: Mon, 21 November 2022, 14:13:49 »
Looks nice
Thank you guys so much!
Offline ariyankb
  • ariyan#9999
« Reply #6 on: Wed, 28 December 2022, 22:21:58 »
I love the design, but the texture of the rubber feet looks strange in the render.
Good Luck!
Offline Xonuss
« Reply #7 on: Mon, 09 January 2023, 13:52:34 »
Good Luck!
Thank you so much! Don't mind the textures too much in the renders, materials are hard. Expect them to be black rubber, or possibly silicone :D
Offline N3OG3M
« Reply #8 on: Tue, 10 January 2023, 04:45:44 »
Love it.
You planning on running it through a vendor??
Would look awesome if you made your logo on the back as a weight instead
But like it as is too.
Would suggest if no changes that you try to keep the price within the 70-90$ range if possible.
Good luck though and will be following updates of the project :)
Offline Xonuss
« Reply #9 on: Wed, 18 January 2023, 08:42:14 »
Love it.
Thank you! I'm still consider whether to run it myself or get in touch with vendors, or a mix, but do have a few vendors in mind that I would like to get in touch with if that was the case.
The back as a weight would definitely look cool, but I fear that would add unnecessary cost to the point where it wouldn't be worth it. Additionally, price is still TBD exactly, but aiming for the best price I can get :D
Offline Morbii
« Reply #10 on: Wed, 18 January 2023, 11:13:00 »
It might be neat to have a special small run Founders Edition with a weight that costs more.  Would also give you the opportunity to figure out those logistics for future products too.
Offline Xonuss
« Reply #11 on: Wed, 18 January 2023, 12:25:54 »
Definitely an interesting idea, this is noted! :D
