Author Topic: [IC] Project Infinité minimalist, industrial 65% keyboard - Updated  (Read 6178 times)
Offline Spacebar_Studios
Project Infinité
A classy, minimal 65% keyboard
Discord:https://discord.gg/rkwUdhedPZ    IC form:https://forms.gle/MonoioZ26gdxDGtx5
Group Buy date: TBD
Intial Renders
282004-0
282006-1
282008-2
282010-3
282038-4
Colour options
Navy (blue) Pantone 2747c
Crimson (red) Pantone 7628c
Violet (purple) Pantone 2597c
Black Pantone 532c
282012-5
282014-6
282016-7
282018-8
282020-9
282022-10
282024-11
282026-12
Case Specs
Typing angle 6°
Front height 19.5mm
Finishing: E white and anodizing for aluminium parts Brass finishing TBD by IC form
Unbuilt weight: Aluminium weight&plate (estimated): 0.75kg, 1.65 lbs
Unbuilt weight: Brass weight&plate (estimated): 1.55 kg, 3.42 lbs
Mounting Style: O-ring top mount
PCB Specs
Hotswap and Soldered versions available
QMK & VIA compatible
5 pin MX switch compatible
Flex cuts inbetween R1-R2 and R4-R5
USB C daughterboard (JST cable included)
Soldered
282148-13
282150-14
Hotswap
282151-15
282154-16
Layout
Soldered Version
282144-17
Hotswap Version
282202-18
Additional Information
Price(Full aluminium): TBD around 400-450 USD
Price(Brass version: TBD around 450-550 USD
Colors fixed unless enough demand met
Plate material: aluminium, brass (will come default on the brass version) possibly POM and FR4
Brass version (brass weight & plate) will be made available but limited amount <50pcs
282030-19
282032-20
Assembly
The design is made up of 5 parts the top body, plate, bottom body, weight and, badge plate. when completely assembled only 4 screws are visible. the 4 screw holes line up perfectly with the 4 filleted corners to have a slightly industrial look to the design. The screws provide pressure to compress the o-rings slightly, the o-rings help to isolate the plate creating a different sound signature. The badge plate locks into the weight and is secured by grub screws instead of more traditional screws due to space constraints. The weight then screws into the bottom body again using grub screws once again. The 2 pegs at the back help for easier assembly for users.
282054-21
282056-22
282052-23
Prototypes have been ordered but may be delayed due to holidays from Chinese New Year
Join the discord and follow us on instagram to stay updated!
« Last Edit: Sat, 12 February 2022, 05:23:12 by Spacebar_Studios »
Offline ZavaZ86
Re: [IC] Project Infinité minimalist, industrial 65% keyboard
« Reply #1 on: Fri, 04 February 2022, 04:22:10 »
No
« Reply #2 on: Fri, 04 February 2022, 04:29:52 »
god, why have you forsaken me
Offline nullinasou
« Reply #3 on: Fri, 04 February 2022, 04:33:06 »
looks good and I found this very interesting until I saw the price
Offline linell
« Reply #4 on: Fri, 04 February 2022, 04:47:27 »
lol nice pricing
lol nice first post
bro this a **** set, just be thankful you even getting 1 base running fr
Offline Pyroo
« Reply #5 on: Fri, 04 February 2022, 04:55:18 »
Bunny enthusiast
Offline Briaireous
« Reply #6 on: Fri, 04 February 2022, 05:49:49 »
How is the badge weight secured to the weight?
It looks nice, out of my price range I think. But GLWIC
Offline MaxineCh
« Reply #7 on: Fri, 04 February 2022, 07:52:25 »
nice renders  :thumb:
Offline treeleaf64
    • treeleaf64
« Reply #8 on: Fri, 04 February 2022, 11:24:14 »
arara raaraaaRAAAA
« Last Edit: Fri, 04 February 2022, 11:32:06 by treeleaf64 »
Everyone must pay the cat tax
Offline SDKCAMPING
« Reply #9 on: Fri, 04 February 2022, 12:02:49 »
The price does not look out of the ordinary to me, especially in today's standards
that being said the design looks pretty ordinary to me, nothing too special, nothing too wrong which may be a plus for other people but not for me. good luck with IC.
« Last Edit: Tue, 24 May 2022, 16:49:34 by SDKCAMPING »
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline nickthaskater
« Reply #10 on: Fri, 04 February 2022, 12:37:40 »
Why this over any other generic weighted rectangle?
Save the materials and machine shop hours for something that's actually different, frankly.
Offline Keeblet_257
« Reply #11 on: Fri, 04 February 2022, 13:18:44 »
just dont support it if you dont like it. If there isnt enough interest this wont be run. No need to be a *******
Offline stewfayew
« Reply #12 on: Fri, 04 February 2022, 15:18:46 »
Are you making this post because you're excited about something you designed? Or are you hoping everyone will be foaming at the mouth to buy another 65% keyboard?
If you're excited about something you made, that's great. Post it on Instagram or Reddit. Share it in someone's Discord server.
From a selling standpoint ask yourself this: would you really be eager to spend $450 on a keyboard that you've only ever seen in renders?
Offline wahfuhls
« Reply #13 on: Fri, 04 February 2022, 18:02:41 »
scrolling through this ic was an ok experience until I saw the layout options and the price tag LOL
Re: [IC] Project Infinité minimalist, industrial 65% keyboard - Updated
« Reply #14 on: Sun, 06 February 2022, 11:57:58 »
Hello to everyone after receiving feedback from the community, changes have been made to the soldered layout, now with 7u spacebar and ISO enter support. Also after receiving feedback on finishes for the brass version has been finalized with a matte sandblasted finish. We are currently working with the manufacturer to try to reduce the costs of the keyboard to make it more accesible to more. We will continue to update you on any changes to the design on both discord and geekhack. Protos should be coming next month.
