Author Topic: Learning curve finding color combo's as a non-designer  (Read 2663 times)
Offline problemxyz
« on: Sun, 06 February 2022, 03:37:40 »
Sometimes I spend so much time googling keysets in the hopes someone already combined with a space gray Q1 (in my case) and put a pic on the internet.
And now that Ive bought two keysets that pan out different than I expected, Im realising its better to figure out how to combine those things on a screen frist.
I have no experience with graphical software and willing to learn a few things. What would I need to learn to have the minimum? I could of course combine images, cut and layer them in some photoshop-like app. But then you have less control, and perhaps changing an angle or may also be not too bad.
Like does it shave of a significant amount off the learning time if you can find 3d models of a bunch of keyboard models and use the 3d software to 'color' them? How can it not of course, but is it relatively easy to find 3d models? Like I wouldn't need and exact model of my Q1 but any exploded 75% would be great for instance.
Or do keycap designers also always draw their keyboards from scratch, when they create renders like this one: https://geekhack.org/index.php?topic=116118.0?
Keychron Q1 Unsilenced Boba u4T silents 55g springs Mistel kecyaps | Keychron K6 Feker Panda MT3 Cyber | GK64 in pieces | Ducky One Full Size PCB broken
