Author Topic: Need your feedbacks - Keycaps Sound Tests  (Read 3124 times)
Offline c.a.t.
  • All about Keyboards sound...
    • Click and Thock
« on: Fri, 25 February 2022, 05:31:29 »
I've made Keycaps Presentation and Sound Tests Videos on my channel and I would like to know your feedbacks before I do some more!
Here the playlist on my channel:
https://youtube.com/playlist?list=PLaACzmtzj5Pks8k4A0ih6rAFbeZK9T8aR
JS
« Last Edit: Fri, 25 February 2022, 05:34:31 by c.a.t. »
JS - aka Click and Thock
Offline Handke
Re: Need your feedbacks - Keycaps Sound Tests
« Reply #1 on: Fri, 25 February 2022, 05:43:23 »
Sincerely I don't care about unboxing, quality of construction etc. A picture or a measuremente in the comments is enough to do that.
The only valuable way to compare keycaps, is to put them on the same keyboard, and split the same video among the different keycaps. It's annoying to open ten different videos to reach the typing section and then try do remember how do they sound... very ineffective, a total waste of time on your and on our part.
Offline c.a.t.
    • Click and Thock
« Reply #2 on: Fri, 25 February 2022, 05:48:13 »
Thanks for your feedback, will do a compilation!
