Author Topic: [CLOSED][GB] DOMIKEY X ZERO-G MIDNIGHT CHERRY PROFILE ABS KEYCAPS  (Read 8300 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
IMPORTANT: GROUP BUY ITEMS ONLY ACCEPT PAYPAL PAYMENT. IF THE ORDER IS PAID BY CREDIT CARD DIRECTLY, IT WILL BE CANCELLED AND REFUNDED.
NOTE - Due to the difficulty degree of manufacturing and other uncontrol factors, any GBs have risks. If the accident happened, please wait patiently. We will update the progress information in time. Thank you so much!
GROUP BUY ITEM CANNOT BE CANCELLED WHEN IT IS CLOSED.
Domikey X ZERO-G Midnight Cherry profile Keycaps
Midnight is full of mystery. There are many stories in midnight around the world.  The Vampire, the Chinese Zombie, the witches and so on.
ZERO-G Studio combines the western and eastern Midnight Figures in its Midnight theme. In the midnight mysterious world, there are no boundaries.
They work with Domikey, the famous and good-reputed keycap manufacturer, to make the Midnight theme as Cherry Profile keycaps.
SPEC
  • Designed by Zero-G Studio
  • Manufactured by Domikey
  • Profile: Cherry Profile (1-1-2-3-4-4)
  • Material: ABS
  • Doubleshot Legends and Tripleshot Janpanese Legends
  • Strip bottom
  • Closed on 20th March (PST)
  • Estimated delivery in September 2022 (PST)
Join KPrepublic Discord and following the latest updates.
Associated theme Switch
Working with the Designer Studio and JWK, an associated theme switch goes with the Midnight keycaps GB.
SPEC:
5 pin MX style linear switch
Top housing: Composite nylon
Bottom housing:Composite nylon
Stem:“LY”
Spring: Stainless steel(gold-plate)
Contacts: High-quality gold alloy
Actuation: 48g
Bottom out: 63.5g
Actuation distance: 2.0mm
Total travel: 4mm
Design by the Designer Studio ,Produce by JWK.
Associated Theme Mousepad
SPEC:
stitched edge
surface - microfibre cloth
900x400x4mm
ZERO-G draws the cute little Chinese zombie, jumping unscrupulously in the western cemetery! ~
Associated Theme Cable
SPEC:
FBB Cables
Connector: USB Type-C
Double layer heat shrink
USB-A:Gold-plated plug + zinc alloy housing
Cable: Double-shielded,24AWG+28AWG,5-conductor
Outer jacket: PU
Sleeving: Parachute cord + pet double sleeve
Detachable connector: Aviator (5-pin)(Chrome Plating&Coating)
Inner coil diameter: 1.25cm
Coil length: 17cm-18cm
Total cable length:120m
JOIN THE GB NOW
« Last Edit: Tue, 07 June 2022, 03:57:12 by KPrepublic »
Offline KPrepublic
  • * Moderator
    • KPrepublic
283075-0
Offline KPrepublic
  • * Moderator
    • KPrepublic
Limited Resin Chinese Zombie Novelty
Offline KPrepublic
  • * Moderator
    • KPrepublic
Groupbuy will close 5 days later!
