Author Topic: [IC] Velocifire X Bling Switch  (Read 3885 times)
Offline john08099
  • Velocifire MK
    • Mechanical keyboards for typers
« on: Tue, 01 March 2022, 21:00:24 »
Hello everyone,
Good news! Let us introduce you to our new project: Bling Switch
Please check Bling Switches Albums
Here's a link to a video of the Bling switch: https://imgur.com/RzLhfaN
Bling Switch Introduction
It is designed by Keyfirst and produced by HM. HM was found by one of Kailh's engineer.
Adding shiny powder to the housing of the switch is not easy to achieve in the process. In order to achieve the best visual effect, it is also necessary to take into account the feel and quality of the switch, which is difficult for us in the first place.
To make the Bling switch from the visual, feel, and quality of the effect to achieve the best, we continue to choose new materials and use a new switch mold to try to make them, and finally achieve the Bling switch that meets our expectations.
The Bling switch has an excellent appearance, a lot of optional pressure grams, and amazing light transmittance. I believe our efforts will definitely make your keyboard shinier.
Product Detail
Linear Switch
Transparent housing with shiny powder
POM Stem
60 grams of Gold Plated Spring
5-pin PCB mount
3.8 MM TRAVEL
2.0±0.5mm Pre-travel
Press life: 6000w
Color: Bling pink, Bling blue, Bling purple, Bling green, Bling yellow, Bling purple
In stock Price: US$0.55 Per switch
Expected In-stock time: Mid-March
If you would love to receive an update, please fill in this IC FORM or Join our discord server  HERE .
Also, feel free to comment here.
Thank you for reading this post.
Velocifire Website: https://www.velocifiretech.com/
E-mail: John@velocifiretech.com
Make Typing Better | Velocifire
Offline stewfayew
Re: [IC] Velocifire X Bling Switch
« Reply #1 on: Tue, 01 March 2022, 21:26:55 »
sparkle thock?
Offline Botty212
« Reply #2 on: Wed, 02 March 2022, 01:45:22 »
would like to see the vendors beeing announced since it's supposed to go in stock mid march
