Author Topic: AEK II Cap Cleaning  (Read 5412 times)
Offline Sparton175
AEK II Cap Cleaning
« on: Wed, 02 March 2022, 20:26:37 »
I just purchased a set of 105 AEK II keycaps for an Alps build I'm working on. I'm planning on giving the caps a good cleaning when they arrive and I was wondering what the best method would be for the PBT Dye-Sub caps, most of my caps are double shot so I want to make sure I don't ruin them.
I have access to a small ultrasonic cleaner and your standard cleaning supplies.
Offline pixelpusher
Re: AEK II Cap Cleaning
« Reply #1 on: Wed, 02 March 2022, 23:06:22 »
I usually just use warm water and dish soap.  Let them soak and then wipe, rinse, wipe, lay dry.  I'm sure ultrasonic would work fine.
Offline Getsome!!!
« Reply #2 on: Sun, 20 March 2022, 17:24:19 »
Best way to clean AEK? Gasoline and a match.
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
« Reply #3 on: Sun, 20 March 2022, 19:24:52 »
Once you get them cleaned if you want to further whiten the keys you can use some peroxide and good ole sunlight.
Offline Riverman
« Reply #4 on: Wed, 30 March 2022, 01:34:30 »
Unless someone doesn't like the original light grey color, there isn't a need to whiten AEK keycaps.  They were all PBT except for the space bar.
Offline Tactile
« Reply #5 on: Tue, 05 April 2022, 13:43:08 »
I've cleaned many cap sets in an ultrasonic cleaner using tap water with a squirt of dish soap. No problem for either ABS or PBT, and great results.
REΛLFORCE
« Reply #6 on: Tue, 05 April 2022, 13:59:27 »
Put them in a mesh washing bag, zip it close and wash the bag as one unit. It makes cleaning and drying them a whole lot easier.
Offline butre
« Reply #7 on: Tue, 05 April 2022, 14:37:41 »
I've had luck with denture cleaner for both abs and pbt caps.
Offline Crabby
« Reply #8 on: Wed, 06 April 2022, 18:36:17 »
Dish soap and a tooth brush and some relaxing music. I don't have to clean keycaps often so I don't need anything fancy.
