Author Topic: [GB]Melody 96 Pro Case RGB Hotswap PCB Kit With Acrylic Bottom And Brass Weight  (Read 8630 times)
Offline vincent88928
  • Have Fun Everywhere
    • YMDK
Why we do the newest version
When we consider the upgrading for our newest 96 kit,the weight is a speical reason.So we add the brass weight for our old kit 1(Melody 96)
And because the reason,we consider more factors.
Compatibility,new function,new feeling etc.
After confirm last with our boss
We choose the same size,but use the speical acrylic bottom with brass weight.
For the situation,we upgrade our hotswap 96 V2 pcb to V3 RGB south facing hotswap pcb.
But sorry for that we still have not prepared ISO layout for this pcb now,will consider it in future.
And consider the better handle feeling in this kit,we upgrade the foam be the new two sets(one for the middle of pcb and plate,another one for pcb below).Still is EVA material.
After you add foam for this kit,we will upgrade the foam to the two sets freely.
283482-0283484-1283486-2283488-3
Vendors YMDK
Contact us with emial:david.chen@ymdkey.com
Contact us with Discord
Case(Black Color)
Top part use aluminum designed,and anodized or powder coated.Weight 0.377 kg,size about 382*136mm.
Bottom part use acrylic with brass weight designed,CNC and anodized.Weight about 0.826kg,size about 381*132mm.
Angle about 5°.
Case height about 20-30mm
283490-4283492-5283494-6283496-7
PCB(Green as the sample,black for production)
Size about 360*112mm
Weight about 0.159kg
RGB South facing
Support VIA
VIA manual:(Will add it after GB,thanks for your understanding)
283498-8283500-9283502-10283504-11
Plate(Black Color)
Melody 96 plate and anodized,size about 366*118*1.5 mm,weight about 0.078kg
283506-12
Black-Clear Gold Wired Screw in Stabilizers
Weight about 0.019kg,use oil better,from this link.
Special note
Our old kit 1 or kit 2 case support this acrylic and brass weight bottom and RGB hotswap PCB.
Color options for Case
New Colors(as the display in colors)
283508-13
Old Colors
283510-14
Price
New colors kit 228 usd
Old colors kit 218 usd
Only PCB 65 usd
Only acrylic bottom with brass weight 75 usd
GB gift of this times in Melody 96 Pro Kit(Only can choose one for one GB Kit)
1)A 1 key switch tester,one random switch.
2)5 usd for this GB in discount code.
Please note if you use the discount,there will have not the other Gifts.
3)A free assembly service for our new Kit,but need add switches together.
4)A opportunity to get a free keycap in order(10 pcs order have one times)
When we confirm the information,will contact with you to provide some sets as option.
We will use a random number to confirm the winner.Such as 7,The 7th,17th,27th etc orders will get the free keycap set of options and a email.
Timeline for GB
Open GB in Mar 10
GB buying time:Mar 10 - Apr 20
Production time:Apr 20 - May 20
Shipping time :May 20 - May 30
Shipping way: FedEx expedited shipping,5-8 days for shipping.
« Last Edit: Wed, 13 April 2022, 04:45:55 by vincent88928 »
Have Fun Everywhere
Approved :thumb:
Offline roostrc0gburn
  • its just plastic
wow. this seems like a great value for the price
Offline Zanduby
Quick question on the powder orange color. Will the final product be a lighter, pastel-ish orange like in the image, or more of a traditional orange.
This sounds like a great deal, and i'm very interested in joining this GB. Just need to figure out which color :D
    • YMDK
Yeah,we will use the same color as the image,so don't worry this.
Have Fun Everywhere
Offline rockydbull
is this pcb and plate compatible with older melody kits?
    • YMDK
Yes,we will prepare the same size for the pcb,so it will fit our old case,plate and kit.
Have Fun Everywhere
    • YMDK
Last time,I just forget that we have upgraded the old foam to the new two sets.Let me add the images tomorrow..Because our camera just went for repairs.
Have Fun Everywhere
Offline cloudconnected
Realy would love to see an ISO Version cuz im from Germany
Can we get the normal Case with Powder White? or is it just a pictury for showing the color and not the case?
« Last Edit: Thu, 07 April 2022, 05:57:58 by cloudconnected »
    • YMDK
I am sorry for that we still have not done ISO layout now...And the Powder white is the display of images,we will do the 96 powder white case for it.
Have Fun Everywhere
    • YMDK
This GB had ended yesterday and into Production time now.Many thanks for your supporting.
Have Fun Everywhere
