Author Topic: MX-compatible switch opener for $6.50  (Read 74819 times)
Offline trauring
    • off on a tangent
« on: Thu, 10 March 2022, 16:06:37 »
A switch-opener that works with most MX-compatible switches. Only $6.50 for a white plastic one, more for other materials.
https://www.shapeways.com/product/ZLA6MAESE/switch-opener
Offline pixelpusher
Re: MX-compatible switch opener for $6.50
« Reply #1 on: Thu, 10 March 2022, 16:32:07 »
I ordered one of these from shapeways about 4 years ago.  It's still going strong after opening several thousand switches.  I will say that in the past few months, I have issues opening some switches such as Bobas with this one.  I dont know if it's worn out, but I suspect it might be.  I have a backup one from primekb that I bought for $10 that does the trick when this one fails.  Good products.
