Author Topic: Need help - ALPS Switches Hot swap  (Read 1955 times)
Offline c.a.t.
  • All about Keyboards sound...
    • Click and Thock
« on: Fri, 11 March 2022, 08:19:20 »
A question for you! I order a paladdin60 pcb, and I want to make it hot swap … Wanted to use mill max but regular ones are not compatible alps switches because the legs are too large… I know there ar some larger mill max who fits Alps switches but I am worried that it would not fit the pcb holes… do you know if someone already do it? Thanks!
JS - aka Click and Thock
Offline NoUbell
Re: Need help - ALPS Switches Hot swap
« Reply #1 on: Fri, 11 March 2022, 11:31:30 »
Very interesting question, I would like to know this as well  :thumb:
desko is naice
Offline Faceman76
« Reply #2 on: Fri, 11 March 2022, 14:13:58 »
I believe BOX switches have the same issue.  I read about a possible solution recently, I'll look for it.
Sent from my SM-G975U using Tapatalk
1800s and heavy springs
