Author Topic: Options for keycaps on a Razer Huntsman Mini  (Read 3922 times)
Offline blackjudas
« on: Fri, 11 March 2022, 14:38:12 »
Hello all, admittedly I'm no expert when it comes to Mech keyboards, I bought a few Das Keyboards and moved on with my life.
Since then, I've acquired a razer huntsman mini, I'd like to replace the keycaps since I use the Colemak layout and I'm not a massive fan of RGB, but the deal was pretty good for the keyboard itself.
So I've done a bunch of research and have come up with not much, either I try and find a replacement set in the Colemak layout, or just simple blanks would work.  Though, the pudding caps seem kind  of neat and doesn't ultimately kill the option to have a set of backlit keycaps.
Either option seems to not be available.  I suppose I could just go with basic blank keycaps that can be found on amazon or on aliexpress.  Any suggestions to the above options or any other options all together?
