Author Topic: AKKO ASA LOW PROFILE PBT DOUBLESHOT KEYCAP FOR MX STEM KEYBOARD  (Read 8063 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
AKKO Carbon Retro Color Scheme
AKKO Carbon Retro keycaps set adopts a few vintage colour combinations of carbon black and off-white and a hint of burnt orange to present a retro feel. The design evokes a sense of nostalgia for the Old West, like a steam train powering through the last leg of a long journey. Well-packed keycaps set with a custom storage box can be an ideal gift for anyone who’s into colours.
ASA Low-Profile Keycaps Full Set
Inspired by the newly popular ASA profile, we are launching the latest ASA low-profile version! Like other low-profile keycaps, the ASA low-profile keycaps have the same height around 8.96mm. It is no need to worry about different-height problems by putting some specific keycaps like PgUp and PgDn on different rows in layouts of 75% or TKL. It is compatible with MX structure switches such as Cherry, Gateron, Kailh, etc. A keycap set that makes your DIY journey worry-free.
Supreme PBT High-Quality Keycaps
For ultimate typing experience and durability, we go with high-quality PBT material instead of ABS. Compared to ABS material, PBT is less common and feel textures and is more durable. It’s dry and not easy to get oily. It won’t wear down over time as ABS does.
Full-Size Set, Suitable for Any Layout
This set of keycaps contains a full-size base set and some extra novelty keycaps. Especially the custom pattern for function keys is easy to use. No matter you got a 60%/75%/80%, TKL or a full-size keyboard, we cover it all. This set will fit any size keyboard. Get one set and make it all work.
Double Shot Technique
The Carbon Retro keycaps adopt the double-shot technique, a more complicated manufacturing process where two separate plastics are injection moulded to make the keycaps. Details and techniques made this set an ideal and the best choice when you are looking for a replacement set.
  • Number of Keycaps: 154 Keys
  • Profile; ASA Low-Profile at the height of 8.96mm
  • Material: PBT
  • Printing Method: Double Shot
  • Special Keys Diagram:
  • - Spacebar: 6.25U/7U
  • - Shift; 2.25/2.75/1.75U
  • - Enter: 2.25/2U
  • - Tab: 1.5U
  • - CapsLock: 1.75U/Stepped keycaps
  • - Backspace: 2U
Purchase Link
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: AKKO ASA LOW PROFILE PBT DOUBLESHOT KEYCAP FOR MX STEM KEYBOARD
« Reply #1 on: Sun, 13 March 2022, 22:39:31 »
