Author Topic: Recommendation for new linear switches  (Read 2125 times)
Offline sandywind
« on: Wed, 23 March 2022, 12:33:26 »
Hello! I'd like to completely and urgently replace the Gateron Black switches on my Planck with JWK switches. I've searched near dealers and so far I've found the following
Prevail Epsilon Switch
DUROCK Lupine
ThicThock & JWK EV-00 Switch
JWK EV-02 Switch
Can you recommend any of those, or point out any problem or unusual feature I should know about before buying?
Tank you!
Corsair Vengeance K65 w/ SP DCS Twilight Keycaps | Poker II w/ Danger Zone keycaps | HHKB Pro 2 | Realforce 87UW55 | IBM PC BS 80's | OLKB Planck | IC WhiteFox | Varmilo VA87ML
Offline granola bar enthusiast
Re: Recommendation for new linear switches
« Reply #1 on: Wed, 30 March 2022, 23:21:29 »
the gateron cj's are a super smooth switch and are said to be smoother than even lubed tangerines stock thanks to their polished stem, they are also in-stock most of the time on divinikey.com or most other vendors that carry them, not jwk's but just as good imo
