Author Topic: [IC] Epomaker Mini Cat 64 Kit - 60% Hot Swappable Acrylic RGB Wired DIY Kit  (Read 4596 times)
Offline EpomakerKeyboard
    • Epomaker
284584-0
Hi everyone!
We are thinking about starting a new Group Buy. It will be much appreciated if you could spend some time giving us some feedback!
Find details in IC Form
Get more updates on our Discord Server
GB Update: the GB has been started! Epomaker Mini Cat 64
It is a 60% hot-swappable cat-shaped acrylic RGB wired mechanical keyboard DIY kit. The design is innovative by being made from cat-shaped stacked acrylic plates. It’s compatible with VIA.
Specs:
Model: Epomaker Mini Cat 64
Number of Keys: 64 keys
Layout: 60%
Hot-swap Availability:  3/5-pin Hot-swappable
Connectivity: USB-C
Case Material: Stacked Acrylic Case
Program: Compatible with VIA
Backlight: RGB
Here are some details and scene images.
Mini Cat 64 DIY kit:
284586-1
Stacked acrylic layers:
284588-2
284590-3
Thank you for your Time!
Epomaker Team
« Last Edit: Wed, 20 April 2022, 06:09:04 by EpomakerKeyboard »
Offline granola bar enthusiast
quite the unique looking case, are the lines on the cat parts of the different layers of acrylic, or small cuts?
    • Epomaker
Thank you for your interest! They are different layers of acrylic.
