Author Topic: Is it possible to disable certain key functions?  (Read 1699 times)
Offline sussyimpostermommy
« on: Mon, 04 April 2022, 15:15:26 »
I own a Ducky One2 mechanical keyboard (DKON1808S) and it has 4 additional keys at the top of the keyboard. They are normally used to open the calculator or adjust volume. This is really annoying since I've set my Discord mute button and other functions for these keys. Every time I mute myself on Discord, it increases the volume or brings up the calculator when I start recording on OBS. Is there a way to disable the original functions for these keys and keep them only as macros?
Offline MIGHTY CHICKEN
Re: Is it possible to disable certain key functions?
« Reply #1 on: Mon, 04 April 2022, 15:33:40 »
Does the ducky have software, I assume you could adjust it in there.
« Reply #2 on: Mon, 04 April 2022, 15:40:41 »
That's one of the downsides of Ducky. I don't believe there is a dedicated software, at least I haven't been able to find one.
