Author Topic: [GB] NEO KNOB KN01 | Industrial Designed | Bearing Mounted Knob (IN PRODUCTION)  (Read 6916 times)
Offline neoknob
    • Neo knob
KN01
SINGLE KNOB FOR ALL ROTARY FUNCTION
GROUP BUY : 9th April 2022 - 2nd May 2022
VENDORS
US- Dangkeebs - $65
CA- Keyspresso - $70
EU- Candykeys - €68
UK- proto[Typist] - £50
AU/Oceania- Daily Clack - AUD 111.00
CN- zFrontier - ¥465
IN- StacksKB - ₹6000
ALL OTHER REGION: Neo Knob - $64.99
Estimated shipping Q3 2022
EXPLODED VIEW
BEARING MOUNTED KNOB
KN01 comes with a bearing mounted knob which makes it wobble free.
PROGRAMING
Set your custom function to knob using VIAL software.
DIMENSIONS
PROTOTYPE
INTRO
KN01 is an industrial design knob for daily usage. It is made out of 6061 aluminium which is CNC turned and milled from a solid rod. You might have used other knobs but they are not as stable as this one, because this one uses a bearing mounted knob which makes it wobble free. It can be programmed according to your need. It can be used for video editing, volume, brightness, media player and many more. It also comes with an EC12 encoder with no detent which makes the knob as smooth as gliding on a butter.
Some of you might be having a question. Does it take click input?
Yes, it takes both rotary and click input. It was the most difficult part of design.
FEATURES
•   WOBBLE FREE KNOB
•   TYPE  - C PORT
•   POWERED BY QMK
•   VIAL CONFIGURATOR COMPATIBLE
•   2-Piece CNC Turned Aluminum-6061
Available in two Variants:
•   Knob : Black | Bottom : Black
•   Knob : Silver | Bottom : Black
What are some examples of KN01 use cases?
•   Audio control - Volume up, volume down
•   Scrolling -Scrolling up, scrolling down
•   Tabbing - Moving between browser tabs
•   Window movement - Movement between the previous window or the next window
•   History scrubbing
•   Undo or redo
•   Scrolling horizontally
•   And many more!
What's in the box?
•   KN01
•   Type-C Cable
Surface Finish:
Bead blasted and anodized
(Final Product will have better finishing closer to render)
Product Page : https://www.neoknob.com
Contact
Email:support@neoknob.com
Please leave your feedback below
« Last Edit: Sun, 29 May 2022, 10:12:02 by neoknob »
Offline Kaitodesu
  • Chief of Custom Keyboards(COCK) at Mecha Malaysia
    • I take photos and videos of Keyboards
Re: [GB] NEO KNOB KN01 | Industrial Designed | Bearing Mounted Knob
« Reply #1 on: Mon, 11 April 2022, 23:45:50 »
could you consider designing a hot-swap solution for the EC-11 rotary encoder? These die over time and innovation in this area would be amazing, coming from a person who had to desolder a faulty one but failed because the solder can slip over to the other side and just create a really annoying afternoon.
(perhaps, mill-max style)
Offline neoknob
    • Neo knob
« Reply #2 on: Tue, 12 April 2022, 13:13:09 »
EC 11 encoder has to be soldered on the pcb or it wobbles a lot more and it can easily come out while rotating the knob. The solder on the encoder can be easily removed using a solder wick and encoder can be replaced easily. KN01 uses EC12 encoder which is much more stable and there is a very rare chance that the encoder will die.
Offline neoknob
    • Neo knob
« Reply #3 on: Thu, 14 April 2022, 13:03:12 »
proto[Typist] is now live!
UK: proto[Typist]
Offline bombay.duck
« Reply #4 on: Sun, 17 April 2022, 15:11:59 »
@neoknob - is there a video of the functioning prototype?
Offline neoknob
    • Neo knob
« Reply #5 on: Sun, 24 April 2022, 12:22:04 »
Daily Clack is now live!
AU/Oceania: Daily Clack
