Author Topic: Gateron Oil King Linear Switch  (Read 7173 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Wed, 13 April 2022, 02:31:38 »
SPEC
  • Housing Material: PA66
  • Stem material: POM
  • Linear switch
  • Spring length is around 20mm
  • Black plated spring
  • Factory lubed
  • Actuation force: 55+/-10 gf
  • Bottom Force: 65+/-10 gf
  • Pre-travel: 1.8+/-0.4mm
  • Total travel: 4.0+/-0.4mm
  • Operating life: 60 Million clicks
Purchase here
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: Gateron Oil King Linear Switch
« Reply #1 on: Wed, 13 April 2022, 02:32:50 »
A brief experience on Oil King
Like its name, Gateron Oil King is really oily. It is factory lubed. Honestly, it may be treated as over-lubed when you get it at the beginning.
Typing feels smooth and quiet.
POM stem and PA66 housing make the Oil King more stable and rigid. The switch uses the whole black design. Even its spring is black plated.
