Author Topic: [IC]YMD-Split 70 Orthogonal Kit  (Read 3740 times)
Offline vincent88928
  • Have Fun Everywhere
    • YMDK
« on: Wed, 13 April 2022, 04:38:02 »
Hi,everyone
    We do the special split 70 orthogonal keyboard this times.And consider whether will do the keyboard now,launch the IC to find more informations.
284876-0284878-1284880-2284882-3284884-4
    The reason for the keyboard:
    When we check the using of 24 numpad,find the orthogonal of factor in the keyboard.
    And after consider the feel of using that is influenced by angle,key of quantity,place etc,create the split 70 orthogonal layout as the keyboard of layout.
    Lastly,we do the standard aluminum case with acrylic layer to keep the keyboard of influence in underglow.
Case
Standard arc inclination aluminum case with acrylic layer,anodized
Integrated Plate with top case.
One side of weight about 325.8 g,size about 136*107*23-33 mm,angel about 5°.
Aluminum screws and rubber feets
284886-5284888-6284890-7284892-8
PCB
35 keys Hotswap RGB underglow PCB as one side,2 pieces totally
VIA supported,can flash it alone or together.
Sample is green color,production will use black color.
Non RGB backlight,wired only.
IC form
If you have the interests for the IC,click here.
« Last Edit: Wed, 13 April 2022, 20:05:51 by vincent88928 »
Have Fun Everywhere
Offline nevin
Re: [IC]YMD-Split 70 Orthogonal Kit
« Reply #1 on: Wed, 13 April 2022, 09:37:24 »
Yay, some split ortho love.
The "IC link" is just a link to your product page.
It's fine if you don't want any feedback, but how are you gauging interest if not using a form? Unless you're just counting page views...?
- When will this be available?
- How much will the kit cost?
    • YMDK
« Reply #2 on: Wed, 13 April 2022, 20:07:13 »
You are right, I forgot the most important part.Let me add it now.
Have Fun Everywhere
