Author Topic: IC Red Herring 75%  (Read 4691 times)
Offline EDITINC
IC Red Herring 75%
« on: Sun, 17 April 2022, 22:14:22 »
Red Herring.
This is a 75% board with a split ergo layout similar to an Alice, but with columnar-staggered keys like the Jabberwocky by NoPunIn10Did. The PCB features all through-hole components with the diodes laid out in a herringbone pattern that follows the contour of the top row keys. I left a lot of room around the rotary encoder, so it can fit a 48mm diameter knob. And finally, front and center is a 64x128 OLED display.
My excitement for this board stems largely from the ability to use standard keycaps. Whether they're cheap or expensive, as long as your kit has that extra 1.75u shift and a 2u key from the numpad, you're probably good to go. The oversized rotary knob is a bit ridiculous, but I personally find it amusing to look at. And even though it adds a lot of heft to the PCB, I love seeing exposed through-hole components, especially when they're laid out nicely.
As I mentioned, this is just a prototype I'm doing for fun, but I am working on a rev 2. The case design will be improved functionally and aesthetically, and the next PCB will support a full 2.25u left shift. I'm also considering moving the caps lock LED up to the top instead of under the key, and also move the knob slightly over to make it look less crowded.
Here are the build details of the pictured keyboard: custom laser cut clear gray/red acrylic case, Red Herring rev1 PCB, FR4 plate, silent Alpaca switches, Durock v2 stabs, Iron Man keycaps from Drop.
Let me know what you guys think! And here's the full album with a few extra pics: https://imgur.com/a/fM5yRbc
I also want to mention all the other amazing board designs that I took inspiration from: Boardrun Bizarre, Adelheid, Discipline & Mysterium, Mercutio, and Basketweave.
everything now is in EARLY stages
Email for Build Date/Purchase Info
Samuellshell@gmail.com
285115-0285117-1285119-2285121-3
Offline Xury46
Re: IC Red Herring 75%
« Reply #1 on: Mon, 18 April 2022, 02:26:58 »
Excellent work, good luck with the interest check!
Offline hottrout
  • I'd Hit Dat Key
« Reply #2 on: Mon, 18 April 2022, 03:38:51 »
Interesting take on Alice.  Interested to see how this goes.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
