Author Topic: 【IC】Gateron Camping switches  (Read 4904 times)
Offline Aregs Keyboard
« on: Mon, 18 April 2022, 11:45:46 »
The camping switch is designed and sold by Aregs Keyboard and Guyue studio. The camping switch is inspired by GMK camping keycaps. After being authorized by the GMK camping keycap designer, we designed this switch with the same color matching as keycaps. They are very classic colors that are still popular and artistic now
  Interestingly, the camping switch is not a simple recolor switch of Gateron. On the contrary, camping is a new mold of Gateron. The camping switch is the first switch to use these molds. The shell is all nylon, and Stem uses the mold of the new version of Gateron Ink in the future!
   Their feel is very smooth, and they have a  uniform factory pre-lubed as oil king, with almost no noise. The 3.4mm travel also brings a good press feeling and a good sound!
Details
* Linear
* 3.4mm travel / 1.2mm actuation
* Stem: POM
* Top Housing: Nylon
* Bottom Housing: Nylon
* Spring: 58g(bottom out)  22mm double extended spring
* PCB mount (5 pin)
* Pre-Lubed from factory
* Manufactured by Gateron
Price:
GB Price:0.63 USD
GB date:2022/05/01–2022/05/20
« Last Edit: Mon, 18 April 2022, 12:07:36 by Aregs Keyboard »
Offline Arithmetics
Re: 【IC】Gateron Camping switches
« Reply #1 on: Mon, 18 April 2022, 16:08:50 »
does anyone actually want factory lube?
Offline kentdo10
« Reply #2 on: Mon, 18 April 2022, 18:51:41 »
Can we do no factory lube?
Offline NihonCK
« Reply #3 on: Tue, 19 April 2022, 01:53:49 »
if its the same lubing method as Oil Kings, then its pretty good tbh
Offline codog
« Reply #4 on: Tue, 19 April 2022, 09:06:03 »
no factory lube please for the love of
Offline elvenmonster
« Reply #5 on: Tue, 19 April 2022, 09:15:32 »
In for factory lube so that I can use these stock.
Offline granola bar enthusiast
« Reply #6 on: Tue, 19 April 2022, 09:27:38 »
nice to see more switches employing the oil king's factory lubing method, these are full nylon switches right? all you said about it was that it had a "nylon shell"
Offline weekendkeyboard
« Reply #7 on: Wed, 18 May 2022, 15:01:20 »
Purchased these ones!  :)
