Author Topic: [IC] PBTfans Purpolch | IN-STOCK NOW  (Read 15363 times)
Offline scottdesigns
« on: Mon, 18 April 2022, 20:35:56 »
PBTfans Purpolch
In collaboration with KBDfans
This set was inspired by the classic Dolch colorway, but with a splash of purple. I recently posted this concept on reddit, and to my surprise garnered a huge amount of interest, so we had to make this a reality.
Since then I have further developed this set with KBDfans, and decided to make it a PBTfans set: a faster, cheaper, and high quality keycap manufacturer. With that being said, we proudly present to you the official PBTfans Purpolch interest check.
BUY IT HERE NOW
This is an in-stock set.
Prices (in USD):
$75 for base kit
$19 for numpad
$18 for spacebars
$29 for 40s
$29 for international
$15 for deskmats
Purpolch Product Page
Join the Discord for updates
Kits
Deskmats
Vendors
Global: KBDfans
Specs
Material: PBT material
Profile: Cherry profile
Production Method: Doubleshot
Manufacturer: PBTfans™
Reminder: Only keycaps included, no keyboard
Compatibility: Cherry MX switches and MX-style clones
Designer: Scott L
Render Gallery
Boards shown below: Odin V2, KBDPAD Mark II, Solar, Kunlun, Maja V2, D60 Lite, Tiger Lite
« Last Edit: Wed, 29 June 2022, 19:36:34 by scott_mk »
Re: [IC] PBTfans Purpolch
« Reply #1 on: Mon, 18 April 2022, 20:36:38 »
Reserved
Offline Neely_12
« Reply #2 on: Mon, 18 April 2022, 21:03:52 »
Would really like to see a text+icon option for the mods. Icon bottom row ain’t it imo
Offline Ashen_21
« Reply #3 on: Mon, 18 April 2022, 21:27:12 »
Love the colours! The deskmats look amazing as well!
Offline Randalljai
« Reply #4 on: Mon, 18 April 2022, 21:55:12 »
I agree
Sent from my Pixel 6 using Tapatalk
Offline 0xtanja
  • need 1.5u supers
    • linktr.ee/tanjarinne
« Reply #5 on: Mon, 18 April 2022, 23:13:13 »
Why are the accent arrows in the spacebars kit?  :confused:
Offline llKanull
« Reply #6 on: Tue, 19 April 2022, 01:40:07 »
Why is there an alt gr for an all icon modifier kit?
Also consider text bottom row.
Offline SDKCAMPING
« Reply #7 on: Tue, 19 April 2022, 02:02:36 »
Color is not bad at all! not sure about kitting but I'm interested if the samples come out good. I know dark colors and pbt are supposed to be bad.
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline treeleaf64
    • treeleaf64
« Reply #8 on: Tue, 19 April 2022, 08:11:25 »
Now he's an old mafia don from back when,
he managed to survive the game, ducking fame
Everyone must pay the cat tax
« Reply #9 on: Fri, 22 April 2022, 19:34:41 »
It is the PBTfans kitting. Samples will definitely be made and I will do the most to ensure the dark colors comes out good. Thank you!
« Reply #10 on: Fri, 22 April 2022, 20:37:11 »
Really into this set! I would love to see more purple though, any chance of an alt alpha kit with purple legends?
« Last Edit: Fri, 22 April 2022, 20:40:14 by unwashed_heathen »
Offline KeyboardTom
« Reply #11 on: Sat, 23 April 2022, 08:32:36 »
Do you know or can you check with KBDfans how well the purple of your set and from the new lite r4 (Vivid Violet) will match? Since both will be manufactured by KBDfans it would be nice it the colors fit :) Doesn't need to be exactly the same color but shouldn't be way of.
The purple arrow keys in the base or nomad kit would be better imho.
« Last Edit: Wed, 27 April 2022, 17:15:59 by KeyboardTom »
Offline twingo
« Reply #12 on: Tue, 10 May 2022, 10:29:50 »
This is so similar to something I made (didn’t order)  on wasdkeyboards, definitely buying.
Offline EdgeOfInfinity
« Reply #13 on: Tue, 10 May 2022, 11:53:06 »
i have way too many purple/gray sets already... why can't i stop lol
Offline fortissim2
« Reply #14 on: Tue, 10 May 2022, 12:57:08 »
I had to clear my bookmarks just to add this in - definitely considering getting it soon :)
« Reply #15 on: Tue, 10 May 2022, 15:03:04 »
6.25u and 7u bars in the spacebar kit are currently identical to the base kit, should probably be accents.
« Reply #16 on: Wed, 11 May 2022, 17:55:13 »
This will be fixed. Thanks for pointing it out.  :thumb:
Offline CONIN
« Reply #17 on: Sat, 04 June 2022, 11:57:51 »
I would get the Base and Nomad kits with no hesitation, but am kinda intrigued as to why the Spacebars kit includes the 6.25 and 7 ones again since they are already present in the Base kit; also, the accent arrows make more sense if they were included in the Nomad kit rather than the Spacebars kit.
Offline Keeblet_257
« Reply #18 on: Sat, 04 June 2022, 15:31:55 »
I agree with him here. I think that it would have been a better idea if the 6.25 and 7u spacebars were in the accent colours instead of grey like the alphas are.
Offline less_blank
« Reply #19 on: Sat, 04 June 2022, 16:23:25 »
You guys might want to read the rest of the thread.
Offline Keeblet_257
« Reply #20 on: Sat, 04 June 2022, 16:31:44 »
am I blind? I just see
1. Inspiration
2. a few links
3. Kitting renders
4. Vendor
5. Specs
6. more renders
7. END
and his comment is still "reserved" so there is no updates?
« Reply #21 on: Sat, 04 June 2022, 20:20:27 »
This kit had been fixed for a while now, I just hadn't updated the kit render. It's on here now, thank you.
« Reply #22 on: Sat, 04 June 2022, 20:21:58 »
As mentioned above, this was marked for fixing and since then has been fixed. Thank you.
Offline CONIN
« Reply #23 on: Sat, 04 June 2022, 20:31:03 »
No, U. Looking great so far!, I do really like the colours combination, hoping to see this one coming to life.
« Reply #24 on: Sun, 05 June 2022, 22:15:49 »
Thank you! You'll definitely see it.
Re: [IC] PBTfans Purpolch | IN-STOCK NOW
« Reply #25 on: Wed, 29 June 2022, 19:37:25 »
The sale is now live! All kits are in-stock, deskmats are currently preorder but will be in-stock in around 2 weeks. Thank you!
Offline CONIN
« Reply #26 on: Wed, 29 June 2022, 19:59:11 »
That was fast. Nice!, will grab the Base, Spacebar and 40s (Nomad) kits for sure!  :cool:
