Author Topic: KAILH BOX V2 WHITE SWITCH RGB SMD LINEAR TACTILE  (Read 9433 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Fri, 22 April 2022, 02:48:17 »
Kailh BOX V2 Linear Switch
SPEC
  • PC housing
  • POM stem
  • Clicky switch
  • around 20mm spring
  • 45+/-10 gf Actuation force
  • 50+/-10gf Bottom force
  • 1.8+/-0.4 Pre-travel
  • 3.6+/-0.3mm total travel
  • 80 Million Clicks
The Switch doesn't support south-facing PCB, the keycap may get stuck.
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: KAILH BOX V2 WHITE SWITCH RGB SMD LINEAR TACTILE
« Reply #1 on: Fri, 22 April 2022, 02:49:03 »
