Author Topic: Excuse my idiot-ness, how to use a Apple Extended Keyboard on Windows 10  (Read 1966 times)
Offline granola bar enthusiast
I was told instead of saying hey all to say "sonic keyboard" by my friend so well okay.
Anyways I was looking around eBay and found this (https://www.ebay.com/itm/175229124999?hash=item28cc784187:g:QhQAAOSw6p9iTI5s), it's a Apple Extended keyboard with Salmon Pink Alp's and I was thinking about getting it but then the thought crossed my mind, how the hell do i use this? It dousn't show what port it uses so I was wondering if someone who had experience with the Apple Extended Keyboard could help me out. Thanks!
You'd need a ADB-to-USB adaptor (also called a "protocol converter"). It should have a Apple Desktop Bus (ADB) port in one end and a USB port (or cable) in the other.
The most common ones are:
* Hasu's. It is programmable so you can change keymap. You can also make one of these from a Pro Micro (or similar board with ATmega32u4 microcontroller).
* Drakware. Pretty recent one with 3D-printed housing.
* The iMate is often available on eBay but pricey because I think they stopped being made some time ago. They stem from twenty-twentyfive years ago when Apple just had switched from using ADB to USB.
Offline Riverman
You'll also need an ADB cable, since that particular keyboard doesn't include one.  If you can't find an actual Apple ADB cable for a decent price, you can use a standard S-video cable.
Thank you all so much! I don't know much about "vintage keyboards" or older tech as a whole so this has been really helpful
