Author Topic: [IC] BINEPAD BN006 - 6 Key Low Profile Macropad  (Read 4745 times)
Offline binepad
« on: Mon, 25 April 2022, 15:19:49 »
Hello Geekhack!
We would like to introduce everyone to BN006
​BN006 is 6 key low profile macropad which is CNC machined from a solid block of aluminium.
Each key can be configured via QMK to do just about anything you want it to.
Please fill out this IC Form if you're interested : https://www.binepad.com/bn006-ic-form
BN006
ALUMINIUM FRAME
DIMENSIONS
PROTOTYPE
FEATURES
•   RGB BACKLIGHT
•   KAILH HOT SWAP PCB
•   CNC Machined Aluminum-6061
•   Programmable by VIA QMK configurator
•   TYPE C PORT
Available in two color :
•   BEAD BLASTED BLACK ANODISED
•   BEAD BLASTED SILVER ANODISED
BN006 SHIPS WITH
•    1 x CNC Machined Aluminium Frame
•    1 x Hot Swap PCB with TYPE-C Port
•    1 x silicon foot
•    8 x M2 Screw
•    6 X Kailh Low Profileswitches
•    6 X Low profile Keycap
•    1 x L-KEY
•    1 X TYPE-C CABLE
Pricing : $50
Please only fill out the form if you are intending on buying.
GROUP BUY IS EXPECTED IN MID MAY 2022
Please leave your feedback below
Offline of_sam
Re: [IC] BINEPAD BN006 - 9 Key Low Profile Macropad
« Reply #1 on: Mon, 25 April 2022, 15:20:55 »
I may be crazy but I only see 6 keys. Title says 9 keys.
Typing on: HHKB Pro 2 - Stock :aware:
Collection: F1.69, Police, Jubi, RF 87U, En Dash, Rosenthal, Soulless, Frog, Calliope, GAF 910, Sabre, W1-AT
Offline binepad
« Reply #2 on: Mon, 25 April 2022, 15:25:49 »
Fixed!!
You can go for BN009
Offline ankit
  • Formerly ankit-sachdeva
Re: [IC] BINEPAD BN006 - 6 Key Low Profile Macropad
« Reply #3 on: Mon, 25 April 2022, 15:41:30 »
This looks pretty cool. Finishing on that proto looks awful though.
Offline neoknob
    • Neo knob
« Reply #4 on: Mon, 25 April 2022, 15:46:01 »
« Last Edit: Mon, 25 April 2022, 15:48:33 by neoknob »
Offline binepad
« Reply #5 on: Mon, 25 April 2022, 15:53:13 »
Yes the sand grid used for proto was too thick. These were only made to check the dimensions. The final product will be much better. Surface finish will be similar to BN009.
