Author Topic: [PRE-IC] Liquid WASD Deskmat  (Read 3396 times)
Offline ocean.setups
« on: Tue, 26 April 2022, 18:26:00 »
Render of the basic design and sample of the matching sticker
285513-0285511-1
About:
Pre-Interest check for the Liquid WASD deskmat.
To check which colour patterns you like to see. You can submit different colour combinations. Background, drops and the WASD itself can be in different colours if you like to. Gradients are also possible. the black and white design will also be available. There will be a regular IC after this one with the different colour options.
Pre-IC duration
27/04/2022 - 04/05/2022
Offical IC will start on 06/05/2022
Specifications
Price: TBA
Size: 900 x 400 x 4
Material: Cloth Ttop surface and rubber bottom
Vendors
EU = Keygem
USA = TBA
UK = TBA
Canada = TBA
Asia = Zion Studios
Australia = TBA
More information about the vendors after the next IC.
Links
https://forms.gle/8vX7mfs2JUXNtMor9
https://discord.gg/Hy3gWWa8
PRE-IC IS CLOSED! OFFICAL IC STARTS ON FRIDAY 6TH OF MAY.
« Last Edit: Fri, 06 May 2022, 04:11:01 by ocean.setups »
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
Re: [Pre-IC] Liquid WASD Deskmat
« Reply #1 on: Tue, 26 April 2022, 18:30:11 »
hey you might be in the wrong subforum
