Author Topic: [IC] Båge - AEK Curved O-ring mount 60 - Vendor Updated, New Prototype  (Read 34500 times)
Offline ankit
  • Formerly ankit-sachdeva
Re: [IC] Båge - AEK Curved O-ring mount 60
« Reply #50 on: Mon, 19 September 2022, 22:14:26 »
deleted, thank you hoffman
« Last Edit: Mon, 10 October 2022, 17:51:53 by ankit »
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #51 on: Tue, 20 September 2022, 15:49:18 »
Yup, that’s not that hard. Infact there are already plates out there that support SP DCS 60, I’ll take some pictures with DCS pingmaster next. The PCB supports MX stabs even though it’s ALPS only, I have that covered.
That is what this is, by design. Just that if AEK isn’t your thing then it works well with other configs as well.
I suppose getting switches and caps might be an entry barrier but that’s what we want to address with this, make it as easy and budget friendly as possible for folks to get into the alps world and then offer premium upgrades for that little something extra.
«How much wood could a woodchuck chuck if a woodchuck could chuck wood?»
Offline atkins
« Reply #52 on: Sun, 09 October 2022, 23:30:05 »
Am I correct to assume that the PCB supports og AEK ISO or is this standard ISO pictured?
Offline nachie
    • KapCave
« Reply #53 on: Sun, 09 October 2022, 23:59:09 »
Standard ISO. OG AEK ISO is not a 15u layout and not supported.
AHKB | GSKT-00 | Arya | Båge | Paladin64
Offline atkins
« Reply #54 on: Mon, 10 October 2022, 01:30:26 »
Thanks for the quick reply. It actually is 15u. Its just that the leftmost keys are 0.25u wider and the rightmost keys are 0.25u shorter than standard - for god knows whichever reasons. Will there be a case only option for oddballs like me?
Offline nachie
    • KapCave
« Reply #55 on: Mon, 10 October 2022, 01:42:50 »
Ah yes, you are right, I was thinking of an ASK for some reason.
I am not sure what format the options would be offered in, but I can try to see if the vendor would be willing to consider it.
Offline toniwonkanobi
« Reply #56 on: Mon, 10 October 2022, 17:38:31 »
Did anyone else get a random notification from geekhack saying the hoffman dude split this topic?
Offline nachie
    • KapCave
« Reply #57 on: Mon, 10 October 2022, 19:01:13 »
I got one as well, not sure what it means. Still seems to be unaffected.
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #58 on: Sun, 27 November 2022, 03:14:04 »
Any news?
Offline nachie
    • KapCave
« Reply #59 on: Sun, 27 November 2022, 03:18:27 »
Any news?
Prototypes for the final (hopefully) designs have been ordered by the vendor with their fab. Both poly and Alu protos were ordered, still waiting to receive and verify those.
Pcbs are good to go, minor tweaks on the final ones, should be getting them next week.
Overall it’s almost there, just have to verify the final design and fitment and announce details on the actual buy.
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #60 on: Mon, 28 November 2022, 06:47:51 »
Great, thank you!
I've noticed Discord invite doesn't seem to work anymore, can you please share another one?
Offline nachie
    • KapCave
Re: [IC] Båge - AEK Curved O-ring mount 60 - Vendor Updated, New Prototype
« Reply #61 on: Wed, 30 November 2022, 17:16:04 »
It's been a while since an actual update.
I'm pleased to announce that CannonKeys will be the vendor for this group buy. They have been incredibly supportive and have been super helpful in making sure we can keep the machining costs as low as possible.
Earlier today, they received prototypes for the GB unit in both Aluminum and Polycarbonate.
  • GB Unit Prototypes
  • O-Ring mount post now use Unikorn positions. This is to make sure CannonKeys Bakeneko60 pcb will work in this case for MX switches. Custom AEK ALPS pcb will be offered of course by default.
  • GB will offer a single color for anodized aluminum case, most likely space grey. This is to keep the option count (and price) in control.
  • GB will also offer a polycarbonate case with heat set inserts.
  • Internal weight only
IC form is still open for those that want to give additional feedback. There was an issue with my discord and I had to nuke it, I'll create a new one and post the link here by the end of this week.
Next up is sending prototype units to streamers to build and review. Also finalizing GB dates, options, prices etc. Will keep the thread posted on when that happens.
« Reply #62 on: Wed, 30 November 2022, 17:22:19 »
Nice! Looking good nachie.
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
« Reply #63 on: Thu, 01 December 2022, 06:51:23 »
Splitting the topic is the usual standard for us moderators to delete spam or inappropriate messages.
How do you pronounce this one    Like  Bagel ?  or Rage   Rayayayay Ayayayaya Yayayayayaayya!!!!!!
https://forvo.com/word/b%C3%A5ge/
Offline hkhawk
« Reply #64 on: Thu, 01 December 2022, 16:51:33 »
Exciting updates, congrats
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #65 on: Sat, 28 January 2023, 10:51:18 »
Any news?
How about Discord?
Can't wait for GB to start! :cool:
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #66 on: Mon, 10 April 2023, 02:55:14 »
Any news?
Offline nachie
    • KapCave
« Reply #67 on: Mon, 10 April 2023, 03:19:14 »
Any news?
PCBs were updated to use STM based processors instead of ATMega to be inline with the rest of the CannonKeys offerings. Proto pcbs, cases and caps/switches etc are with CannonKeys, waiting for scheduling time with streamers to do a couple builds on stream.
Also, created a new discord with an additional verification step built in to combat bot spam from last time. Link updated in the original post.
Stream news should be following in the coming weeks, followed by a date for the GB. A couple things needed to get redone which took some time, thank you for being patient :)
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #68 on: Mon, 10 April 2023, 03:52:18 »
Thanks so much for the update, awesome! :thumb:
Offline jordowag
« Reply #69 on: Mon, 10 April 2023, 22:02:55 »
Can't wait! This will be my first custom alps board :thumb:
