Author Topic: [IC] GHS.JEM - A screwless seamless 65% keyboard  (Read 20678 times)
Offline GoneHackingStudio
« on: Fri, 13 May 2022, 09:41:19 »
More photos here.
IC form
GHS.JEM
Screwless seamless 65% keyboard
by Gone Hacking Studio
est. Australia 2020
Gone Hacking Studio is composed of three keyboard enthusiasts that share the same passion
and commitment towards the hobby. Following the success of the GHS.RAR, we aim to provide the same high-end features in a 65% form factor.
Join our Discord server for faster updates.
Argent
Azul
Noir
Blanc
Jade
The PCB has tabs that you attach silicone sleeves onto. It then fits snugly into the case. Plateless is an option.
Typing tests
Specifications
Case material Aluminum
Plate material Aluminum (anodized black), POM, PC, CF, brass (sandblasted)
Colors available Silver, black, blue, e-white, jade (special edition)
PCB Matte black, ENIG finish, 1.2mm PCB with flex cuts
Weight material sandblasted brass (standard kits),
 sandblasted brass or copper (special edition),
 optional upgrades to mirror-finish stainless steel, or dark PVD brass
Dimensions 331mm × 134mm × 37mm
Typing angle 6.9°
Case weight 3.3kg
Price US$490 (standard), US$590 (special edition)
Kit Contents
Four (4) M2x4 Hex Screws
Eight (8​) M2x6 Hex Screws
Four (4) M2.5x25 Hex Screws
Four (4) M2.5x12 Hex Screws
Twenty (20) Silicone sleeves
One (1) GHS.JEM PCB
One (1) Aluminum full plate
One (1) USB-C Daughterboard
One (1) Daughterboard cable
Four (4) Silicone rubber feet
One (1) GHS.JEM Top
One (1) GHS.JEM Bottom
One (1) GHS.JEM Weight
Add-ons
Aluminum full plate US$42
POM full plate (black) US$42
Polycarbonate full plate US$65
Polycarbonate half plate US$65
Carbon fiber full plate US$38
Carbon fiber half plateUS$38
Brass full plate US$62
FR4 plate TBA
GHS.JEM Hotswap PCB with Standoffs and Daughterboard US$65
GHS.JEM Solder PCB with DaughterboardUS$65
Layouts
Solder Layout
Hotswap Layout
Socials
Facebook Instagram
Twitter Discord
IC form
« Last Edit: Fri, 13 May 2022, 10:04:18 by GoneHackingStudio »
Offline Ella
  • Why is it called an oven
Re: [IC] GHS.JEM - A screwless seamless 65% keyboard
« Reply #1 on: Fri, 13 May 2022, 09:45:19 »
But does it thock like the jelly ethocc?
Offline P103
« Reply #2 on: Fri, 13 May 2022, 10:00:36 »
Are there more details on how much the upgrade to pvd and dark brass going to cost? Also, why does a color change and option to swap to copper cost $100?
Offline Adelscott
« Reply #3 on: Fri, 13 May 2022, 10:26:04 »
Please think about ISO users, add a split left shift to your "alice style" keyboards
Offline sup3r170va
« Reply #4 on: Fri, 13 May 2022, 11:49:33 »
Looks good. Is the effective front height (not the lip but the spacebar row of keys) on the tall side? Would a wrist rest be necessary?
Offline SDKCAMPING
« Reply #5 on: Fri, 13 May 2022, 15:25:59 »
The shape of the board is a little off to me but I can see the appeal for something like this, good luck!
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline MSA_Vision
« Reply #6 on: Sat, 14 May 2022, 05:20:48 »
Been following this board for a while, congratulations on the IC launch!!! :thumb:
I do think that if someone wants to get sandblasted brass in jade, they should not be paying $100 extra just for colour. However, dropping jade+brass and only offering Jade+Copper config as the special variant would make more sense for the incremental cost.
Sic Parvis Magna
Offline JKratos
« Reply #7 on: Sun, 15 May 2022, 09:32:39 »
Damn son, im in love with that jade colorway, i have only one question will EU vendor be available?
« Reply #8 on: Sun, 15 May 2022, 22:32:33 »
We will finalize the upgrade cost based on how the demand is upon IC. At this stage its around $50 upgrade. Jade isnt just a color swap, you are looking at 10-15% of the total number of units being limited in color gives extra cost and not to mention the option to choose any plate material and a Copper weight.
« Reply #9 on: Sun, 15 May 2022, 22:34:01 »
Thank you for the kind words. Most of the RAR users didn't actually require a wrist rest although we have designed one for the RAR and have also designed one for the JEM which we shall be launching soon.
« Reply #10 on: Sun, 15 May 2022, 22:34:33 »
Thank you for the kind words. stay safe
Offline DaaDaa
« Reply #11 on: Sun, 15 May 2022, 23:50:34 »
This needs a red color, bright lipstick red. The Jade doesn’t quite hit the spot
piggy60 red upgraded PVD w/ GMK umka zaku | tiramisuit w/ GMK noire JWK silk emerald | mr.suit black/chrome glossy chamfers w/ GMK minimal cow POM stem | jelly epoch w/ SA oblivion zaku | mode80 deco w/ gmk boneyard alpaca | mode 80 imperial with ePBT origami alpaca| MODE80 viridian /w CRP boba LT | RAMA thermal kuro w/ GMK muted 2 pewter | BBox60 C64 wih marshmellows and c64 keycaps | MODE Sonnet green /w MW voynich gateron ink box pink
Offline menuhin
« Reply #12 on: Mon, 16 May 2022, 04:11:43 »
Please consider providing step caps lock support on the hotswap pcb.
Very excited about this project, checking all the boxes!
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline LegendsWorks
  • thocc
« Reply #13 on: Mon, 16 May 2022, 04:52:50 »
Why add gasket tabs to the side, Wouldnt that just make the board stiffer?, Love the cherry lip though its pretty dank, GLWIC :thumb:
Offline ajcroix
« Reply #14 on: Thu, 19 May 2022, 01:50:37 »
would love the hotswap pcb to enable stepped caps config. GLWIC!
« Reply #15 on: Fri, 20 May 2022, 22:16:18 »
Thank you for taking time in reading this IC. will pass this on my team re your lipstick red request. Have a nice day!
« Reply #16 on: Fri, 20 May 2022, 22:17:20 »
Hi, Thank you for the kind words. I think the steep caps lock was brought up on our meeting and have considered this with our hotswap PCBs. Let me confirm this for you
« Reply #17 on: Sun, 22 May 2022, 10:50:02 »
Hi, Thank you for taking the time and noticing our JEM. We've been happy with our tests and so far as per builds and comments from others, there was no significant stiffness on the board :)
Offline superjackie
« Reply #18 on: Wed, 25 May 2022, 01:50:27 »
Could you post pictures for dark PVD brass? How much is the PVD brass upgrade cost?
Offline Akele
« Reply #19 on: Wed, 25 May 2022, 14:20:50 »
I'd be interested in seeing the dark PVD brass weight and the stainless steel one too. I'm not a fan of the standard brass weight, but the copper one does look very good.
« Reply #20 on: Fri, 27 May 2022, 05:29:46 »
Thank you for taking time on this. The dark PVD Brass weight is exactly the same finish as the GHS.RAR Scarlet's Dark PVD Weight
Offline mr_foggy
  • neue = nope
« Reply #21 on: Mon, 30 May 2022, 07:47:44 »
jade + copper please.
« Reply #22 on: Wed, 01 June 2022, 10:38:58 »
Offline deska
« Reply #23 on: Wed, 01 June 2022, 10:56:20 »
personally not usually a fan of 65s but that front lip is amazing!
« Reply #24 on: Thu, 02 June 2022, 11:29:55 »
Appreciate the kind words :)
