Author Topic: [IC] PBTfans Doubleshot/Tribleshot Rim PBT Keycaps  (Read 6569 times)
Offline sososoya
« on: Fri, 13 May 2022, 13:56:07 »
PBTfans Rim
Join Discord Server for updates XD
Intro
This article is translated by Google.
Long time no see, this is Soso.
At the end of last year, I released Rim's IC post, which has been delayed until now due to various reasons. During this period, I also listened to everyone's feedback. Today, I will bring you the latest information on Rim.
Previous IC links:https://www.zfrontier.com/app/flow/4KbP1zQg0mX5
I am very happy to work with PBTfans to make this set of keycaps. The keycaps are made of PBT material, Cherry profile, using doubleshot/tripleshot craftsmanship, and the characters are designed by the well-known designer Biip. I believe that the quality of the keycaps will not disappoint everyone.
Inspiration
The keycap is inspired by the character Rim (リム) in "迷宮ブラックカンパニー", which is a very cute character. The color matching refers to the color of Rim's hair and horns, and a color similar to ruby is chosen as an embellishment.
Next, I will share with you the latest renderings.
Kits
The new version of the design has made major changes to the novelties, which is more in line with Rim's setting as the "Dragon of Gluttony”.
A new set of Rim's same emoji emojis have been added. In short, they are very cute.
Rendered by Rifen
Renders
Rendered by York chan
Deskmats
Newly designed table mat, there are two styles to choose from.
Keyboard Collab(Currently in China only)
The keyboards tailored for Rim will be released by lottery.
The specific information of the keyboard will be disclosed in the group buying post.
Other collab accessories are also in the plan. Please look forward to it.
Contact
If you like Rim, you can learn about the latest developments of keycaps in the Dsicord server. I will update the latest progress of Rim from time to time in the group.(I will communicate with you using Google Translate XD)
Discord server:https://discord.gg/cFXNcGUbcf
Disclaimers
The rendering may be different from the actual product, please refer to the final product.
Offline finalarcadia
Re: [IC] PBTfans Doubleshot/Tribleshot Rim PBT Keycaps
« Reply #1 on: Fri, 13 May 2022, 14:04:51 »
Very cool
Sent from my SM-S908U1 using Tapatalk
Offline sososoya
« Reply #2 on: Fri, 13 May 2022, 14:08:41 »
i'm glad you like it! XD
Offline ankit
  • Formerly ankit-sachdeva
« Reply #3 on: Fri, 13 May 2022, 14:56:47 »
Has KBDFans addressed the flashing issue apparent with PBTfans spark yet?
Offline NihonCK
« Reply #4 on: Sat, 14 May 2022, 20:08:59 »
Flashing? I saw only a tiny amount at best. Did you have a large amount on yours?
« Last Edit: Sat, 14 May 2022, 20:28:05 by NihonCK »
« Reply #5 on: Sun, 15 May 2022, 09:20:18 »
This might be embarrassing... But what the hell is flashing lol
