Author Topic: Kailh Taichi and Clione Limacina Switches  (Read 10603 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Fri, 13 May 2022, 22:08:13 »
Kailh Ultimate Taichi Linear Switch
SPEC
  • PC housing
  • POM stem
  • Linear Switch
  • 20mm Spring length
  • Actuation Force 45+/-10 gf
  • Bottom Force 58+/-10gf
  • Pre-travel 1.3+/-0.3mm
  • Total travel 3.6+/-0.3mm
  • 80 million clicks
Check here
Kailh Clione Limacina Switch
SPEC
  • PC housing
  • PA stem
  • Tactile / Linear Switch
  • Sping length around 20mm
  • Actuation Force 42+/- 10gf
  • Bottom Force 58 +/- 10gf
  • Pre-travel 1.9+/-0,4mm
  • Total travel 4.0+/-0.4 mm
  • 50 million clicks
Switch buy here
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: Kailh Taichi and Clione Limacina Switches
« Reply #1 on: Fri, 13 May 2022, 22:09:33 »
