Author Topic: Can anyone tell me what keyswitch is this?  (Read 1934 times)
Offline chet0
« on: Tue, 21 September 2010, 12:46:40 »
Old favourite: Logitech Internet Keyboard.
Just wondering what kind of key switch it is?
Keyboards owned: XD87 with lubed aliaz, a few Topres, Logitech 815 (tactile).
Offline Phaedrus2129
« Reply #1 on: Tue, 21 September 2010, 12:49:21 »
Rubber domes, and relatively crappy ones at that.
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline didjamatic
« Reply #2 on: Tue, 21 September 2010, 13:09:58 »
Some key caps have stems connected to key caps (1 piece) that slide through a plastic plate and rest on rubber domes/membrane below.  When you pop those caps off, you see a hole with rubber down inside.
This board you have has a stem/slider that is separate from the key cap so it vaguely resembles a mechanical ALPS switch, but it is really a rubber dome.
