Author Topic: Does this exist?  (Read 1411 times)
Offline Aardwolf
Does this exist?
« on: Tue, 21 September 2010, 15:43:04 »
Does the following exist:
A black keyboard key cap, that can fit on a filco keyboard with cherry mx switches, that has a linux penguin symbol on it (same print type as the other keys of said keyboard), and that has the same shape as the windows key of said keyboard. Both the left and the right one.
Thanks.
« Last Edit: Tue, 21 September 2010, 15:45:18 by Aardwolf »
Offline ch_123
Does this exist?
« Reply #1 on: Tue, 21 September 2010, 15:44:21 »
Das sells them, and as far as I know, they should fit the Filco too.
See here.
Offline Aardwolf
Does this exist?
« Reply #2 on: Tue, 21 September 2010, 15:46:34 »
Quote from: ch_123;225219
See here.
Oh, super! Found it here: http://store.daskeyboard.com/Linux-Keycaps-Das-Keyboard-Users/dp/B003AM0XJI
Can anyone confirm that they work on Filco keyboards?
Offline Aardwolf
Does this exist?
« Reply #3 on: Tue, 21 September 2010, 15:48:06 »
Um, does Das even ship to anywhere outside the US at all?
Offline runeazn
Does this exist?
« Reply #4 on: Tue, 21 September 2010, 15:48:37 »
See here.
Quote from: Aardwolf;225221
prtty a confirmation :)
nvm i honestly dont know try and see, maybe somebody else alrdy tried :)
Kami Ducky 1087 of Heaven
Offline ch_123
Does this exist?
« Reply #5 on: Tue, 21 September 2010, 15:50:56 »
I'm almost certain that I have seen someone put a blank Das windows key on to a Filco, but I'll let someone who has attempted such a feat personally confirm for you.
Put it this way - both the Das and Filco are based on the same keyboard made by the same OEM. Without being able to show you an example off the top of my head, you can swap the keys.
Offline phatkau
Does this exist?
« Reply #6 on: Tue, 21 September 2010, 18:08:48 »
Yep, I can also confirm they will fit perfectly. I have done the opposite - full set of blank Filco keys swapped on to a Das - so yes, both brands are fully interchangeable.
SpaceInvaders Filco Ninja Brown
