Author Topic: [IC] Theca x Rubrehose | Group Buy November 16-30th  (Read 53822 times)
Offline densus designs
  • * St. Jude Supporter
Re: [IC] Theca x Rubrehose | Colour Options Finalised, Updated internals!
« Reply #50 on: Thu, 09 June 2022, 18:11:02 »
KBD67 lite and many other boards that use silicone gaskets had an extremely stiff feel and the silicone did not help the boards in the slightest, how is the flex on this board?
Hello, from some googling I’ve found that KBD67 line is mounted from a layer of silicone throughout the plate that acts as a plate dampener aswell as the mounting gaskets. This pad looks very stiff and is a very different method of mounting compared to how Theca is mounted. Theca’s gaskets are 30A durometer which is quite flexible as well as them being several mm thick on each sides. From typing on theca with the carbon fiber plate, there isn’t too much flex considering it is a stiff material but I will definitely try it again with PC, POM and FR4.
« Last Edit: Thu, 09 June 2022, 19:48:24 by densus designs »
« Reply #51 on: Fri, 10 June 2022, 06:37:31 »
Pricing Update:
Note: Kit doesn't include PCB, KLC will be stocking both Hotswap and Soldered PCBs on their store. The board will come with Daughterboard and JST Cable. The board is also compatible with most 87 layout PCBs that have a JST Connector.
You will be able to choose between Stainless Steel and Brass for the external weight, the internal weight is brass and cannot be changed. All weights are clear coated.
Plates: Aluminium, Carbon Fiber and PC will be available in Full Plate.
Black Ano will have a RED Alu Plate
E-Beige and Brown will have a Black Alu Plate
- Base Kit  ~ 520USD
(no upcharge for e-beige)
- Carbon Fiber Plate ~ 35USD
- PC Plate ~ 35USD
What is included in the base kit:
- Top
- Bottom
- Plate
- Internal Weight
- External Weight
- Daughterboard + JST Connector
- 8x 30A Gaskets
- Top Mount Screws
Topre Kit ~ Pricing Still Pending
Will include:
- Plate
- PCB
- Screws + Standoffs
In other news, i will be passing Theca and Rotor to MechaStore for review so stay tuned for building and sound tests!!!
Offline zzkhan1996
Re: [IC] Theca x Rubrehose | Final Pricing Update!
« Reply #52 on: Fri, 10 June 2022, 07:09:03 »
Is this unlimited GB or FCFS?
« Reply #53 on: Fri, 10 June 2022, 07:12:41 »
Group buy will be unlimited for a limited time frame
Offline zzkhan1996
« Reply #54 on: Fri, 10 June 2022, 07:19:35 »
Will there be any vendors from SEA or Asia?
« Reply #55 on: Fri, 10 June 2022, 07:24:59 »
KLC is located in South Korea and will be the only vendor
Offline zzkhan1996
« Reply #56 on: Fri, 10 June 2022, 07:25:21 »
Thanks
Offline sirieous
  • help
« Reply #57 on: Fri, 10 June 2022, 12:22:30 »
Bit on the expensive side but the reworked internals are appreciated. GLWGB
Offline LMarci
« Reply #58 on: Tue, 14 June 2022, 07:25:14 »
Really nice looking board. Might pick this up.
« Reply #59 on: Tue, 14 June 2022, 09:02:25 »
Yeah I like this. GLWGB
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #60 on: Wed, 22 June 2022, 18:59:41 »
Wanna see a picture of e-beige
« Reply #61 on: Wed, 22 June 2022, 19:48:44 »
A sample picture is e-beige has already been posted on thread.
E-beige prototypes of theca are currently in production, photos of them will be taken when possible.
For those that wanted to see what e-beige looks like, here is e-beige on a new lin whale!
interested in e-beige. got any more photos?
please consider trying to run small duration unlimited GB over raffle
« Reply #62 on: Thu, 30 June 2022, 02:21:36 »
Update 30/6/22:
- 20A hardness gaskets have ordered and will be tested against current 30A gaskets.
- Photos of the Topre PCB have been uploaded onto the IC with updated information about layout options.
Offline ankit
  • Formerly ankit-sachdeva
« Reply #63 on: Thu, 30 June 2022, 05:12:12 »
Love that PCB.  :thumb:
Offline Neely_12
« Reply #64 on: Thu, 30 June 2022, 08:05:21 »
Would the topre addon kit work with other boards if I were to get a plate made or will it only work in this case?
Offline JSaintS
  • Formerly eNrageDSainT
    • JSaintS
« Reply #65 on: Sat, 02 July 2022, 17:13:53 »
This looks really good! I really like the Topre PCB design, will the same design be on the MX variant?
« Reply #66 on: Sun, 03 July 2022, 01:37:10 »
Hello, since the pcb is not included in the kit. I think that many people would buy 3rd party pcbs or the ones currently instock on KLC's store. however we will consider adding the artwork to a pcb for theca! Thanks for the suggestion
Offline Riizmaa
« Reply #67 on: Mon, 08 August 2022, 01:55:54 »
god sent me he said to add si support poggers
« Last Edit: Mon, 08 August 2022, 01:58:31 by Riizmaa »
Offline nonuser
« Reply #68 on: Mon, 08 August 2022, 02:00:32 »
I really like the wolf, the wolf is my spirit animal. Matter of fact, I consider myself an alpha wolf  :cool: :cool: :cool: GLWIC  :thumb: :thumb: :thumb: :thumb: AWOOOOOOOO
Offline B_D
    • bdskeyboards
« Reply #69 on: Mon, 05 September 2022, 13:21:27 »
Yes please
height=120]https://imgur.com/rPWNMJz.png[/img][/url]
Re: [IC] Theca x Rubrehose | Build streams happening now!
« Reply #70 on: Sat, 15 October 2022, 01:59:45 »
Hello,
Xanniard is now live building a brown theca!!
Go check him out
https://www.twitch.tv/xanniard
« Reply #71 on: Tue, 25 October 2022, 07:17:36 »
Hello Friends, a lot of info has been updated including more information on pricing, extras and FAQs.
Ive also added a list of the build streams happening! The discord link didn't seem to be working, so it has now also been fixed.
Offline nonmemo
« Reply #72 on: Sat, 29 October 2022, 17:27:28 »
I was wondering how reconfiguration of keymap and calibration can be done on the topre kit, or if they are necessary.  Thanks.
« Reply #73 on: Sun, 30 October 2022, 09:10:37 »
Hello, the topre PCB will be flashed with VIA and VIAL where you can remap. I'm not 100% sure about calibration, but the board has been tested to set the correct values.
Offline nonmemo
« Reply #74 on: Sun, 30 October 2022, 11:40:28 »
Thanks for your reply.
Offline whirlwind
« Reply #75 on: Thu, 03 November 2022, 13:17:54 »
13 days left, very exciting!
Wow! Can you believe it?
Soon available at KLC and Cafege!
I won't miss it!
 :thumb:
Offline Re-Kid
« Reply #76 on: Fri, 04 November 2022, 02:55:34 »
Did anyone try with alps too? How I wish this collab could go further like buying option for bbw's keycaps as well, for example: big fat Lucy:)
Follow the guts.
« Reply #77 on: Fri, 04 November 2022, 03:46:17 »
sorry not alps support avail and no options to buy artisans
Offline Re-Kid
« Reply #78 on: Fri, 04 November 2022, 19:43:43 »
Could you give more info on the manufacturer side? Like, will it be the same manufacturer with other boards, for example, Lin whale or something else?
Follow the guts.
Offline The_judge_168
« Reply #79 on: Sun, 06 November 2022, 19:19:59 »
Board looks great! Will there be a topre build stream before sale?
« Reply #80 on: Mon, 07 November 2022, 04:14:29 »
Hey, there wont be a build stream but i can take photos while building and try to make a sound test after.
Also
Theca GB will start on November 16th and be open for two weeks, closing on the 30th. GB may close early if soft cap is met.
