Author Topic: [GB] PBTfans Basin | Delivered!  (Read 28788 times)
Offline Nqrwhql
  • Hi :)
« on: Mon, 23 May 2022, 01:17:48 »
PBTfans Basin
GB: June 1st-30th, 2022
Shipped September 2022 - Delivered
Hello fellow enthusiasts:
We are proud to introduce PBTfans Basin! We worked super hard to bring you this set.
Please consider filling out our feedback form and joining our Discord server for support and giveaways!
Feedback Form: CLICK HERE
Discord Server: CLICK HERE
About the Set:
We present to you PBTfans Basin! This set was designed to reflect the dynamic blue-grays of the ocean. Amidst the vastness of an oceanic basin are a wide variety of colors, and we have chosen a sinking gradient to portray diving into the depths of the ocean.
About the Designers:
Asynq Designs is a team that consists of three people: Aiden, Synthereal, and Nqrwhql. We each spent the last year learning and designing up until this point to present this set to you.
Contents
PBTfans
Due to the wait time for ePBT, we have decided to switch our manufacture over to PBTfans. If you aren't already aware, PBTfans is a new manufacture created by KBDfans.
For more info about PBTfans click "more".
Why change?
If we go with ePBT, the gradient color difference wouldn't be as significant as we envisioned. Additionally, ePBT currently has a long queue they need to clear up before starting new sets. Finally, this change is also better for you guys because you would be receiving your order sooner at a lower price.
What's the difference?
Instead of reverse dye-sub, it'll be double-shot on PBT plastic. In simpler terms, the legends are injected, look sharper, and will never fade or chip. Usually, double-shot is much more expensive than reverse dye-sub but in this case, it won't be. In fact, it'll be cheaper than our ePBT prices which used reverse dye-sub. This is largely because of the preset kits we need to follow which makes manufacturing much easier and faster.
What are the new wait times looking like?
Say goodbye to the 1-2 year wait times and say hello to 2-3 month wait time. This is because instead of approving the samples months after GB we have already approved the samples.
Are there any quality issues that I should know about?
As far as I can tell after testing other PBTfans sets, I can confidently say that I have had no issues with it and I daresay that these sets are better than GMK sets. The keycap thickness is 1.6mm whereas GMK is 1.5mm.
Vendors
The keycaps can be bought at:
NA: Kono
CA: DESK[H]ERO
EU: MyKeyboard
UK: KeebCats
ASIA/GLOBAL: KBDfans
OCE: Daily Clack
Price
Note: These prices should be final but are subject to change.
Basin Kit Renders
Adriatic Kit Renders
Deskmats
Designed By Skeil
Ikki68 Aurora By Wuque Studio
Phoenix by Cable Car Designs
White GMMK By Glorious
Black GMMK By Glorious
Nemui By Bachoo
SixtyFive By Mode
Maja By Vulcan
Adriatic Maja By Vulcan
Collabs
Skull Keycaps x Basin
The raffle will be held on June 3rd and it'll last 24 hours.
You'll be able to find the purchase link in our Discord Community or Skull Keycap's Instagram / Discord.
MoziCaps x Basin
Microticaps
Coming Soon! Please join our Discord for updates.
KrakenKap
Coming Soon Please join our Discord for updates.
KeyCraving
Colors
Note: Please understand that the colors you see in the renders may look different from the physical colors. Please be aware that physical colors cannot be replicated in webspace.
Please consider filling out our feedback form and joining our Discord server by clicking on the images below.
By filling out our short feedback form helps us tremendously!
Special Thanks To
Swishy: This set would've never reached IC without you! Thank you for the countless hours you spent with me in a VC, answering all my dumb questions.
Matthewdias: Thank you for all your amazing suggestions and help with kitting.
Mirubere: Thanks for answering all my questions and giving me your honest opinion on this set!
Hank: Without your rendering help, my renders would've looked like they came out of a 32-bit game.
Mcheddadi: Thanks for all the support and suggesting we do a blue alternative set.
Skeil: Thank you for designing the amazing deskmats! (He's also running a IC so check it out here!)
Signature
If you would like to support this set please add this signature and spread the word.
To add a signature go to Profile -> Modify Profile -> Forum Profile -> Signature
Code: [Select]
[url=https://geekhack.org/index.php?topic=112592.0][img width=249 height=86]https://i.imgur.com/Lh7USY9.png[/img][/url]
« Last Edit: Wed, 05 March 2025, 04:31:37 by Nqrwhql »
Offline Nqrwhql
  • Hi :)
Re: [GB] PBTfans Basin | GB: June 1st - 30th
« Reply #1 on: Mon, 23 May 2022, 01:18:18 »
To Do List
Update Log
Make sure to join our Discord Community for more frequent updates and to be notified when we modify our GB thread.
Offline Nqrwhql
  • Hi :)
« Reply #2 on: Wed, 01 June 2022, 00:53:49 »
The raffle will be held on June 3rd and it'll last 24 hours. Raffle is over. Thank you to everyone who participated!
« Last Edit: Thu, 09 June 2022, 11:19:58 by Nqrwhql »
Offline Surefoot
Re: [GB] PBTfans Basin | Now Live!
« Reply #3 on: Wed, 01 June 2022, 06:33:54 »
Fantastic :) Good luck with the GB. Getting a complete kit here...
Offline mcheddadi
« Reply #4 on: Wed, 01 June 2022, 11:33:25 »
PBT Basin. best blue set.   :thumb:
Offline Nqrwhql
  • Hi :)
« Reply #5 on: Thu, 02 June 2022, 18:14:30 »
Thanks for the support!
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #6 on: Wed, 08 June 2022, 23:51:58 »
« Last Edit: Fri, 24 June 2022, 20:20:37 by dvorcol »
Offline Nqrwhql
  • Hi :)
« Reply #7 on: Wed, 15 June 2022, 03:36:50 »
Halfway through Group Buy! Thanks for all the support!
Offline Nqrwhql
  • Hi :)
« Reply #8 on: Thu, 23 June 2022, 00:06:40 »
8 days left! If you haven't already make sure to pick one up.
More artisan reveal soon!
Offline dvorcol
« Reply #9 on: Fri, 24 June 2022, 20:20:09 »
Edit: one more vendor updated
« Last Edit: Mon, 27 June 2022, 13:17:37 by dvorcol »
Offline dvorcol
Re: [GB] PBTfans Basin | Awaiting final numbers!
« Reply #10 on: Fri, 08 July 2022, 16:24:41 »
<-- without extras
Edit: four kits canceled
« Last Edit: Fri, 22 July 2022, 12:01:09 by dvorcol »
Offline Nqrwhql
  • Hi :)
« Reply #11 on: Wed, 20 July 2022, 15:38:45 »
Unfortunately the International, Adriatic International, 40s, and Adriatic 40s are going to be cancelled. We tried our best to negotiate with KBDfans and other vendors to buy more kits but they were all unwilling to invest so much money into kits that might not sell.
If you're wondering why I said all kits will be made above: KBDfans told us that all kits are able to be made with a increase in price. We announce that immediately after hearing about this. A few days later, they notified us that the price to manufacture the International, Adriatic International, 40s, and Adriatic 40s is too high and not worth it.
We have almost no control over this situation and this was a decision made by KBDfans and the other vendors. We want to apologize to everyone who invested their time and money into this set thinking they'll receive a international or 40s kit. You should contact your vendor to see how GB cancellations work and whether or not you would like to cancel your whole order or only that one kit. Again, we apologize if this situation affected you.
Offline TyPo.mk
« Reply #12 on: Wed, 20 July 2022, 17:45:24 »
Based on my experience with KBDfans I am not shocked one bit.
Offline Nqrwhql
  • Hi :)
Re: [GB] PBTfans Basin | Shipping!
« Reply #13 on: Wed, 21 September 2022, 21:16:11 »
Production has been completed and extras are now for sale on KBDfans. We appreciate all the support from everyone!
- Asynq Designs
Offline oscdawg
Re: [GB] PBTfans Basin | COMPLETED! Prepping for R2...
« Reply #14 on: Sat, 31 August 2024, 09:40:38 »
Hoping for a second round of this keyset. Really love the Adriatic Base!
