Author Topic: Keycaps - 1u or 1.5u Bottom Row  (Read 2426 times)
Offline EZG
« on: Mon, 23 May 2022, 08:00:48 »
Hey guys,
I've been looking for a while but I have no hopes anymore. Is there a place I can find these keycaps or some, in PBT and light compatible please ? (doubleshot would be amazing but pretty sure it doesn't exist)
L-CTRL, L-WIN, L-ALT, R-ALT, R-WIN, R-CTRL (1u or 1.5u)
R-SHIFT (1.75u)
Thanks ! Have a great day !
Offline LASERman Projects
  • Soldering is my native language.
Re: Keycaps - 1u or 1.5u Bottom Row
« Reply #1 on: Tue, 24 May 2022, 06:14:30 »
1.5U Win keys are the only unusual exception here, all others are standard in extended sets unless you want all of those first 6 in the same size.
Offline EZG
« Reply #2 on: Tue, 24 May 2022, 11:26:35 »
Standard bottom row is 1.25 for all and 6.25 for spacebar.
I'm struggling to find keycaps set in PBT and light compatibility
« Reply #3 on: Tue, 24 May 2022, 12:41:35 »
I was referring to typical extended keycap set that is covering more than this.
Usually there are keys there for Tsangan: 1.5u / 1u / 1.5u / 7u spacebar / 1.5u / 1u / 1.5u
and also at least Ctrl, Alt, Fn in 1u.
I am struggling to find what bottom row you are looking for.
« Last Edit: Tue, 24 May 2022, 12:44:33 by LASERman Projects »
