Author Topic: Gaming: disadvantage through usb switch using?  (Read 10339 times)
Offline CeeSA
« on: Wed, 22 September 2010, 08:17:46 »
Hello geekhack community,
first of all, i am fascinated  of all the diskussion about inputdevices and modifications.
I am hot of trying a mechanical keyboard first time.
by then i have a question.
Do you think using a USB Switch between 2 pc and the keyboard is a disadvantage for gaming performance?
i did not feel something but i am curious  to know your opinion.
USB Switch like this:
http://cgi.ebay.com/2-Port-USB-2-0-Sharing-Switch-Printer-Splitter-Scanner-/130433879567?pt=LH_DefaultDomain_0&hash=item1e5e770e0f
When i use a 2 pc usb 3 items switch for keyboard and mouse do you think
this is a disadvantage ?
thank you!
Offline zefrer
« Reply #1 on: Wed, 22 September 2010, 09:23:05 »
USB KVM switches are supposed to not have any latency. Try it, if you don't notice anything then it should be fine.
Avoid IP based KVM switches however, also known as iKVM for some retarded reason. IP/network based KVM switches _do_ introduce latency.
Offline Moogle Stiltzkin
« Reply #2 on: Wed, 22 September 2010, 09:49:41 »
Are the USB to PS/2 adapters that come with Filco and Cherry keyboard acceptable ??
Royal Kludge discount code:
Lowyat15
15 USD discount.
Offline lmnop
« Reply #3 on: Wed, 22 September 2010, 10:04:29 »
yes.
Offline itlnstln
« Reply #4 on: Wed, 22 September 2010, 10:13:40 »
*Facepalm*
Offline lmnop
« Reply #5 on: Wed, 22 September 2010, 10:19:47 »
Offline itlnstln
« Reply #6 on: Wed, 22 September 2010, 11:03:29 »
Mandingo would cause too much latency; size isn't everything.
(Cue premature ejaculation joke...)
Offline Rajagra
« Reply #7 on: Wed, 22 September 2010, 15:43:03 »
This is one area where USB switches can be better than PS/2 ones. With PS/2 the driver (like SetPoint) can lose track of what mouse you have so it reverts to acting as a 2-button standard mouse. With USB you force the mouse to reinitialise when you switch, so you don't get that problem.
Offline Phaedrus2129
« Reply #8 on: Wed, 22 September 2010, 15:51:34 »
Quote from: ripster;225498
Raj, I'll convert you yet!!!!
The real reason I don't like PS/2 is I have to get under my desk in the dark and it's scary down there.
My computer is on my desk. ;)
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline CeeSA
« Reply #9 on: Wed, 22 September 2010, 16:34:38 »
thx 4 the welcome :)
my switch comes with a little traysoftware to switch the device so i could keep sitting on my a...
