Author Topic: Hello!  (Read 4039 times)
Offline SkieR3D
Hello!
« on: Fri, 27 May 2022, 05:58:46 »
Hi!
I'm visual effects and computer graphics artist with passion to all new and tech.
As new person in key-dev, here to find some answers and present my own design.
Kind regards!
Offline fortissim2
Re: Hello!
« Reply #1 on: Fri, 27 May 2022, 14:26:14 »
Welcome to GH! I love that keyboard design :D
I think the number row should be moved a bit to the right though, the 1 key might be a little hard to reach from the home position.
Offline granola bar enthusiast
Re: Hello!
« Reply #2 on: Fri, 27 May 2022, 16:24:19 »
o/ welcome to GH,
The keyboard might profit from the top row being moved to the left a bit as it's going to be pretty hard to reach over to esc and other stuff from typing position
Offline epicdesk.shop
Re: Hello!
« Reply #3 on: Fri, 27 May 2022, 16:53:07 »
Hi there, welcome!
Offline SkieR3D
Re: Hello!
« Reply #4 on: Fri, 27 May 2022, 17:05:37 »
Thanks for answers. About layout still thinking, but main thing was about full size, problems only about hex geometry, every row should be shifted by half button and it makes not comfortable arrows. , Also trying to understand which chip to use. At present time trying to do on Atmega32u4. Also found some Japanees matrix to increase numbers of keys.
Re: Hello!
« Reply #5 on: Wed, 06 July 2022, 02:39:48 »
Your keyboard looks very techy, but I quite like pink, is there a pink version?
