Author Topic: [GB] Block-67 R2 - Budget CNC Gummy O-ring 65% | LIVE 28/5 to 5/7 (Extended)  (Read 4765 times)
Offline ENG Studio
    • Discord
The Block-67 is based on the open-source CNC Bakeneko65 but with improvements in every major area. The multi-layout hot swap PCB provides the same compatibility as a solder PCB. The sharp, blocky external design language is one of a kind. As for the internals, it's been completely reworked to optimize sound and resulted in a front height 1.5 mm lower than the Bakeneko65 (17mm vs. 18.5mm). Round one GB participants have praised the Block-67's slightly higher 7-degree typing angle. We are working with reputable international vendors to make this a compelling offering for everyone, not just Americans - which is a first for budget O-ring mount 65% boards.
Features and Specifications:
  • Anodized CNC 6061 Aluminum case
  • 17 mm front height
  • 7-degree typing angle
  • Multi-layout hot-swap PCB
  • O-ring gasket mount
  • QMK & VIA support
  • Aluminum plate
  • Daughterboard and JST cable
  • Universal 8mm rubber feet
  • 55A O-ring
Kit Includes:
  • 1x Block-67 CNC machined aluminum case
  • 1x Multi-layout hot-swap PCB
  • 1x Aluminum Plate
  • 1x USB-C Daughterboard + Cable
  • 4x 8mm Universal Rubber Feet
  • 1x 55A Gummy O-Ring
Vendors:
Renders and photos:
Full album https://imgur.com/a/iF7jxop
PCB Compatibility:
Group Buy Details:
  • GB runs from 28/5 to 5/7 (Extended by a week)
  • ETA: Q4 2022
  • Anodized Black, Grey, Lavender, Navy, Red, Rose Gold 160 USD
  • E-white 165 USD
  • Available plate addons: FR4, POM, Polycarbonate, Brass
  • Other available addons: Hot-swap PCB, Daughterboard, 30/55A O-ring, Foam Kit
  • Pricing may vary by region
Sound Tests and Reviews:
More reviews coming soon!
Sound Test by sviz - "Review should be coming out in a few weeks, but it is absolutely insane how good the budget market is becoming. This board I especially like for the price because it does not RELY on PE foam or any other major mods. "
Sound Test by Filled Types
Epsilon Keyboards - "I'm still using it as a daily driver regularly. Think it's great."
Sound Test by Tap Tap Tien
Build Stream by JayVerb
To vendors and content creators
Keyboard vendors can contact us to stock the Block-67. Right now there is no O-ring mount 65% in stock outside of the US.
Review units for content creators are still available! Don't hesitate to ask for one!
Join our Discord for updates
« Last Edit: Fri, 24 June 2022, 10:05:05 by ENG Studio »
Offline ENG Studio
    • Discord
Re: [GB] Block-67 R2 - Budget CNC Gummy O-ring 65% | 28/5 to 28/6
« Reply #1 on: Sat, 28 May 2022, 10:21:33 »
Reserved
Re: [GB] Block-67 R2 - Budget CNC Gummy O-ring 65% | LIVE 28/5 to 28/6
« Reply #2 on: Wed, 08 June 2022, 08:56:31 »
Approved :thumb:
