Author Topic: [GB] GMK Prussian Blue - Cancelled  (Read 8584 times)
Offline NoPunIn10Did
    • NoPunIn10Key
« on: Wed, 01 June 2022, 09:04:56 »
Bear by Jacky. Render by Manzel. (Full Size)
GMK Prussian Blue
Dates & Vendors
The Group Buy for this keyset has begun! It is expected to run through 01 July 2022.
We are currently estimating shipping to be circa Q3 of 2023, but I wouldn't be surprised if it goes a big longer.
Pricing
Code: [Select]
Product              | MOQ | CannonKeys | MyKeyboard | Prototypist | Deskhero |  ilumkb | Switchkeys |
                     |     |        USD |        EUR |         GBP |      CAD |     SGD |        AUD |
Polish / US Base     | 250 |     135.00 |     144,99 |      130.00 |   179.00 |  199.00 |     216.00 |
German Base          | 250 |     135.00 |     144,99 |      130.00 |   179.00 |  199.00 |     216.00 |
Spacebars            | 150 |      23.00 |      25,00 |       22.00 |    31.00 |   35.00 |      38.00 |
International Kit    |  50 |      55.00 |      53,00 |       53.00 |    73.00 |   81.00 |        n/a |
Hibi Pudding Artisan | 150 |      45.00 |      50,00 |       44.00 |    60.00 |   67.00 |      60.00 |
UK and EU pricing includes VAT.  US and CA pricing excludes sales tax.  AU pricing includes GST.
Updates
01 Jun 2022 - Start of Group Buy.
09 May 2022 - Updated international kit, added vendor list, and announced GB date.
11 Mar 2022 - Updated spacebar kitting to include both types of 6u bar; removed 1.75u bars.
04 Mar 2022 - Submitted for quotes via primary US vendor.
Background
What is GMK Prussian Blue?
GMK Prussian Blue is a custom keycap set to be manufactured in the Cherry profile by GMK Electronic Design GmbH. These MX-compatible keycaps will be made from ABS plastic and doubleshot legends (with UV front-print where needed). GMK Prussian Blue uses a simple color scheme with a GMK stock white (CP) for its legends and a custom color for the base: RAL 230 20 20 (Preußischblau).
Background: Prussian Blue
Prussian Blue is a chemical compound originally discovered in Berlin at the turn of the 18th century. It has been used in a variety of settings from art (Japanese woodblock painting) to architecture (a traditional blueprint dye) to medicine (a treatment for heavy metal poisoning).
Prussian Blue was also used for nearly two centuries to dye the military uniforms of the Kingdom of Prussia. The RAL standard and this keyset draw from this darker variant, and GMK Prussian Blue’s kitting takes further inspiration from the history of the Kingdom of Prussia itself.
The Kingdom of Prussia
The Kingdom of Prussia was established circa 1701 and existed until approximately 1918. Its borders changed frequently, with many of its parts split into separate enclaves and exclaves. Though it was ruled by a German-speaking monarchy, its reality was far more diverse, including regions of Germans, Poles, Lithuanians, and Silesians. For most of its existence, however, the majority of Prussian territory lay within the current borders of Germany and Poland.
Two Base Kits
As a reflection of the Kingdom of Prussia’s multilingual and multicultural footprint, GMK Prussian Blue will offer two distinct base kits: one Polish and one German.
Polish/US Base Kit. Render by Manzel (Full Size)
German Base Kit. Render by Manzel (Full Size)
The Polish / US Base kit will use the modern “Polish Programmers’ Layout,” whose similarity to US ANSI allows it to also serve as the primary base kit. Its modifier key legends will be a mix of icons and English language modifiers. Especially when paired with the Spacebars addon, it provides physical compatibility for very wide array of boards, including a majority of 40% boards as well as rarities like the Vortex Race 3 and Boardwalk.
The German Base kit will follow a German QWERTZ standard layout while also providing a QWERTY option. Its modifier key legends will use a mix of icons and German language modifiers, with most following the style of boards sold by GMK’s own Uniqey storefront. Its physical support for nonstandard keyboard layouts is intentionally more limited to control costs.
Child Kits
Spacebars kit. Render by Manzel (Full Size)
International Kit. Render by Manzel (Full Size)
The Spacebars kit provides a range of spacebar sizes for split & smaller keyboards.  It also includes two 6u spacebar keys: one with a centered stem and one with an off-center stem, allowing it to fit classic Cherry G80-1800 models.
The International Kit provides enough keys to convert the US / Polish base kit into a UK layout or into a more accurate US layout with no sublegends. Likewise, it contains the keys necessary to convert the German base kit into a Swedish, Finnish, Danish, or Norwegian layout.
Hibi Artisan
Hibi Pudding Artisan Cap.  Renders by Hibi. (Full Size: 1  2 3)
Board Renders
Full resolution renders are available on the GMK Prussian Blue Home Page.
All renders provided by Manzel.
Renders may contain inaccuracies and should not be considered the final authority on the appearance of the caps.
Bear by Jacky with Polish / US base & spacebars kit.
Mech27 TKL with German base.
Set Comparison Chart
GMK Prussian Blue will include one new custom color (RAL 230 20 20). Its legends will be GMK stock white CP. Below is a diagram that compares the estimated RGB hex colors of several prior and upcoming GMK and Signature Plastics keysets with those of GMK Prussian Blue.
Full Size
Acknowledgements
Thanks to my amazing wife, who has remained supportive even as my home office fills with more keyboards, keycaps, color standards, and cardboard boxes.
Thanks to my adorable daughter, who brings me such joy.
Thanks to Afresh & konstantin for their immense help with getting the ogoneks right.
Thanks to Manzel for his professionalism and renders.
Thanks to hunghingdailo, who gifted me with a brilliant logo.
Thanks to all my vendors, without whose help this set wouldn't have been possible.
Profile Signature Code
If you would like to show your support and help advertise GMK Prussian Blue here on Geekhack!
Code: [Select]
[url=https://nopunin10did.com/gmk-prussian-blue/][img width=135 height=120]https://diplomacyvariants.files.wordpress.com/2021/12/gmk-pb-logo-135x120-1.png[/img][/url]
« Last Edit: Thu, 09 June 2022, 08:28:29 by NoPunIn10Did »
Re: [GB] GMK Prussian Blue - Polish/US & DE Base Kits - Live until July 1
« Reply #1 on: Thu, 02 June 2022, 11:07:13 »
Approved :thumb:
Offline Peter6109
  • Working on my own set.
« Reply #2 on: Thu, 02 June 2022, 11:32:11 »
tis is lit
Offline roostrc0gburn
  • its just plastic
« Reply #3 on: Thu, 02 June 2022, 13:06:28 »
i like this.
Offline Bub
    • big bub's beepers
« Reply #4 on: Thu, 02 June 2022, 13:53:17 »
GLWGB nopun!!
respectable kiting choices as always
    • NoPunIn10Key
Re: [GB] GMK Prussian Blue - Cancelled
« Reply #6 on: Thu, 09 June 2022, 08:31:31 »
I regret to inform you that we have cancelled this Group Buy.
A huge thanks to all of my vendors, collaborators, and customers: I'm sorry that this didn't work out as hoped. I really think this set could do very well in some form in the future, but based on the sales of the past week (which will remain confidential), this clearly isn't the right moment for GMK Prussian Blue.
