Author Topic: Wrong Keys Registering  (Read 2997 times)
Offline sbunschu2
« on: Fri, 03 June 2022, 14:54:37 »
Hi all,
I have a CU80 that worked fine for a few months (after I fixed the lifted pads with help from geekhack).
However, suddenly some keys are completely mixed up:
- Escape and ^ are switched
- Caps Lock and Control are switched
- Backspace registers as #
- Alt does not seem to work but the Windows key triggers Alt
I am using the ISO DE layout by the way and other keyboard work fine.
Is this a hardware issue or should I try flashhing the software?
Re: Wrong Keys Registering
« Reply #1 on: Fri, 03 June 2022, 20:30:21 »
That's a lot of randomness for one small fix - I'd try re-flashing the firmware first.
Offline FractalOne
« Reply #2 on: Sun, 05 June 2022, 18:01:02 »
software first then hardware check them in that order
Offline sbunschu2
« Reply #3 on: Mon, 13 June 2022, 15:11:21 »
Hi guys, seems like it was indeed a software issue.
I flashed the keyboard using a Youtube QMK tutorial and now it works fine (just the RGB lighting is different than before).
Thanks for confirming that I should check the software first :)
