Author Topic: [IC] LM60 - Low-budget CNC Case GH60 compatible  (Read 9546 times)
Offline daviddgm
« on: Tue, 07 June 2022, 18:18:44 »
LM60
LM60 is a low-budget CNC Aluminum Case for 60% custom keyboard. It is a poron gasket mount and alow you to use GH60 style PCB and popular D65 poron gaskets from kbdfans.
Interest check form: https://docs.google.com/forms/d/17xQUQTow66ULzjp9RcdDTY7yX80AqO0QswBBIipAd6o
Demonstration video with typing test:
Instagram: @lm_kbd
DETAILS
  • Case Angle: 6.5 degrees
  • Mounting: Poron gasket mount
  • Case Material: 6063 aluminum
  • Making process: CNC - sandblast - anodizing
  • Front Height: 19mm
  • Back Height: 21mm (with chamfer) and 31mm (before chamfer)
  • Weight: ~1300g and ~1840g (mounted)
  • Plate:  Aluminum, Brass, FR4 or PC
  • Gaskets: D65 poron gaskets (65x4x3mm)
  • PCB Compability: GH60 style (GH60, DZ60, BM60, etc)
  • Expected price: USD 85-90 (case bottom+top and plate)
Options to be defined
  • Case top for HHKB and WKL
  • Screwless (internal screws)
Photos
« Last Edit: Sun, 12 June 2022, 18:14:36 by daviddgm »
Offline Backspace2
  • Third most used key on the keyboard is Backspace!
Re: [IC] LM60 - Low-budget CNC Case GH60 compatible
« Reply #1 on: Tue, 07 June 2022, 19:46:29 »
How would this compare to a regular o-ring mounted tofu?
Yes
Offline daviddgm
« Reply #2 on: Tue, 07 June 2022, 20:05:31 »
I have tofu o-ring mounted too... This have better sound, better design in my opinion and heaviest...
Offline granola bar enthusiast
« Reply #3 on: Tue, 07 June 2022, 21:02:08 »
85-90 USD for a CNC'ed gasket mount board seems nice, would like some more info on the IC though. also you posted this in IC section twice
Offline daviddgm
« Reply #4 on: Tue, 07 June 2022, 21:10:07 »
Which informations do you want?
« Reply #5 on: Tue, 07 June 2022, 23:15:55 »
im going to go sleep now so i will finish this post tomorrow but i would recommend looking at the IC's of some relatively popular keyboards and see how you can implement some stuff they have in theirs
« Last Edit: Tue, 07 June 2022, 23:20:43 by granola bar enthusiast »
Offline Backspace2
« Reply #6 on: Wed, 08 June 2022, 09:59:46 »
Could we get an in-depth view of how the gaskets are placed? Also, in your IC, the color option was only allowing me to pick one color, but I had a few in mind. If you changed that to multi-select, that would be awesome.
Yes
Offline daviddgm
« Reply #7 on: Wed, 08 June 2022, 18:07:59 »
Hi! Check the design images and you can see on the video at time 1:00. I changed the IC to multi-select color. Thanks for the contribution.
Offline SDKCAMPING
« Reply #8 on: Wed, 08 June 2022, 19:52:22 »
The price is very nice, hard to believe almost!who is selling it and collecting our money and what is the shippingtime?
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline daviddgm
« Reply #9 on: Wed, 08 June 2022, 20:16:05 »
To launch GB I Will ask the customers about suggestions of vendors/payments methods (PayPal?!). I have contacted more than 12 companies to got this price and execute de prototype. Shipping Will be 45-60 days after GB ends.
Offline Backspace2
« Reply #10 on: Wed, 08 June 2022, 22:54:17 »
Thanks for the pictures! Very nice to see you're responding fast to these comments, I appreciate it!
Yes
Offline LegendsWorks
  • thocc
« Reply #11 on: Thu, 09 June 2022, 03:17:10 »
Look awfully similar to the keychron board, Good pricing though  :thumb:
Offline daviddgm
« Reply #12 on: Wed, 29 June 2022, 04:05:07 »
Hi! I want to choose the blue and grey (and pink for my daughter)... Who can help with best hue color using the Ral palette?
« Last Edit: Wed, 29 June 2022, 04:31:44 by daviddgm »
« Reply #13 on: Wed, 29 June 2022, 06:45:17 »
Colour matching anodizing is hard and many GBs end with boards that are different colours to what people were expecting, this is a budget oriented buy so you don't want to be spending lots on samples to match custom colours.
If you have someone in mind to do the anodizing ask for some samples of shades of those colours they can do reliably and chose from them :thumb:
Offline rossi94
« Reply #14 on: Wed, 20 July 2022, 09:06:52 »
Any chance for e-coat variants?
Offline daviddgm
« Reply #15 on: Fri, 22 July 2022, 07:22:43 »
Maybe, It Will depend the orders, because e-coating need at least 50pcs/color.
Offline daviddgm
« Reply #16 on: Fri, 22 July 2022, 07:29:47 »
The LM60 blue color is done.
« Last Edit: Fri, 22 July 2022, 14:55:49 by daviddgm »
Offline Ventamora
« Reply #17 on: Sat, 23 July 2022, 15:48:53 »
Happy to see that there's still progress here. i'm still pretty much interested in getting one. Will it be available from different vendors in different parts of the world or from one internationally shipping place?
Offline daviddgm
« Reply #18 on: Wed, 27 July 2022, 04:37:00 »
Dear, for the first small lot it Will not be available to the vendors, but direct international shipment from the factory. Did you fill the IC form? Because I sent email to the interested people yesterday. If not, fill the IC or give me your email that I will foward to you.
« Last Edit: Wed, 27 July 2022, 06:20:02 by daviddgm »
Offline borison
    • Download Kiddion Mod Menu Latest Version
« Reply #19 on: Thu, 28 July 2022, 08:19:37 »
I will definitely buy this keyboard :)
Offline SzGeri
« Reply #20 on: Thu, 28 July 2022, 10:33:55 »
Any plans for a white option in the future?
Offline daviddgm
« Reply #21 on: Thu, 28 July 2022, 13:15:17 »
Hi! Did you fill the IC form? Thank you.
Offline daviddgm
« Reply #22 on: Thu, 28 July 2022, 13:17:55 »
Yes, and I want one white too, but we need at least 30pcs of white to make...
