Author Topic: [IC] LM60 - Low-budget CNC Case GH60 compatible  (Read 4269 times)
Offline daviddgm
« on: Tue, 07 June 2022, 18:20:58 »
LM60
LM60 is a low-budget CNC Aluminum Case for 60% custom keyboard. It is a poron gasket mount and alow you to use GH60 style PCB
and popular poron gaskets D65 from kbdfans.
Interest check form: https://docs.google.com/forms/d/17xQUQTow66ULzjp9RcdDTY7yX80AqO0QswBBIipAd6o
Demonstration video with typing test:
Instagram: @lm_kbd
DETAILS
  • Case Angle: 6.5 degrees
  • Mounting: Poron gasket mount
  • Case Material: 6063 aluminum
  • Making process: CNC - sandblast - anodizing
  • Front Height: 19mm
  • Back Height: 21mm (with chamfer) and 31mm (before chamfer)
  • Weight: ~1300g and ~1840g (mounted)
  • Plate:  Aluminum, Brass, FR4 or PC
  • Gaskets: D65 poron gaskets (65x4x3mm)
  • PCB Compability: GH60 style (GH60, DZ60, BM60, etc)
  • Expected price: USD 85-90 (case bottom+top and plate)
Options to be defined
  • Case top for HHKB and WKL
  • Screwless (internal screws)
Photos
« Last Edit: Wed, 08 June 2022, 06:46:13 by daviddgm »
Offline daviddgm
Re: [IC] LM60 - Low-budget CNC Case GH60 compatible
« Reply #1 on: Tue, 07 June 2022, 18:28:15 »
Moderation, please delete this duplicate topic. It was caused by connection error. Sorry!
Offline DirtyGingy
« Reply #2 on: Tue, 07 June 2022, 19:32:18 »
Is the plate a universal layout? I have a very unusual build I want to do that is GH60 compatible, but very uncommon on the layout.
Offline daviddgm
« Reply #3 on: Tue, 07 June 2022, 19:57:30 »
Yes, universal.
Offline DirtyGingy
« Reply #4 on: Tue, 07 June 2022, 20:05:17 »
Yes, universal.
It *should* work, but do you think Milan layout would work on it? the odd spacing and placement of left control, the 3u spacebar, and split backspace seem like they could be troublesome
Offline daviddgm
« Reply #5 on: Tue, 07 June 2022, 20:11:31 »
Yes, universal.
I need to check, but the plate customization is not a problem.
