Author Topic: [GB] Domikey Adventurer keycaps  (Read 4683 times)
Offline GLOVE
« on: Sat, 11 June 2022, 10:13:53 »
Design Concept
Hi guys, Glove is here. I am happy to bring you a new keycap theme.
 It is inspired by an adventure that a warrior saves the princess.
The warrior wears his green battle suit, climbs over hills and mountains, pass through the forest to save his princess.
Meanwhile, it is a theme about Spring Camping.
We need to go outside and camp in Spring, to feel the nature. We can go to travel, go camping, etc.
At the beginning, I intend to create different colour scheme for ALPHA kit, one is mainly Blue, the other is mainly Green.
After collecting the feedback from the community, I finally decided to remove the blue Alpha design.
Since the Green suit is more classical colour scheme for a warrior like Peter Pan.
The green suit, yellow hair and brown feather glove. Therefore, I add brown colour in green Alpha.
Since I wanted to use tow different colour on Alpha, I had to remove blue and green from MOD kit and white novel kit and used yellow characters.
However, the character is hard to recognize. Eventually, I adjusted the colour of character to green for MOD kit and White Novel.
Final color scheme
Render
Keyboard color matching
KIT
There are 60 novels in total.  In Base Pro kit, there are 28 novels so that the Base kit is more interesting.  In Novel kit, there are 32 Novels.
Due to the addition of R4 2U Novelkey (backspace) and R3 1.5u Novelkey (TAB), the purchase of base and additional alpha will enable the assembly of two keyboards
Base pro 2: $115
Base pro 3: $125
Alpha 2: $29
Alpha 3: $39
UK: $9
Num: $16
Bar: $12
Novel: $35
All in one: $220
Resin Novelty Weirdo Link: $59
Jelly Cosplay Mousepad - Green: $22
Jelly Cosplay Mousepad - Blue: $22
Manufacturer: Domikey
Keycap Materials: ABS plastic
Technique: Double shot and triple shot
Keycap Profile: Cherry Profile
GB Time (PST)  : 15th June -  30th June
Estimated delivery: October
ABS plastic color card
“Weirdo” Artisan keycap
Material: Resin
Manufacturer: ZMKC
Includes: ID card (the number is based on the order of placing orders), collection box, collection base, stickers
GB: Sell with Keycap set
Estimated delivery: ship with keycaps
Relegendable Keycap
Material: ABS Doubleshot
Manufacturer: DOMIKEY
Includes: 9 R1 height (ESC row) Keycaps and 4 stickers
GB: Because the sticker process is not mature, it is a gift for all in one.
Associated Theme Mousepad
The lovely Dongdong wares a pair of Spirit ears, play as the warrior in blue suit and Green suit.
The figure that printed on the mousepad is drew by Natural Pride Studio and GLOVE.
Material: natural rubber, multispandex, stitched edge
Process: heat transfer printing
Size: 900mm * 400mm
Vendors
   USA: KPrepublic
AU: Mountain KBD
Thank you for your attention and support!
« Last Edit: Fri, 24 June 2022, 08:03:11 by GLOVE »
Re: [GB] Domikey Adventurer keycaps
« Reply #1 on: Fri, 24 June 2022, 13:27:05 »
Approved :thumb:
Offline DirtyGingy
« Reply #2 on: Fri, 24 June 2022, 13:59:09 »
I would have loved the blue version, but the set still looks good
Offline GLOVE
« Reply #3 on: Sat, 25 June 2022, 01:59:11 »
Approved :thumb:
Thank you for your answer! :D
