Author Topic: I made an open source 40% Keeb  (Read 2524 times)
Offline bishopj7
    • Clack-Attack
« on: Sun, 12 June 2022, 22:00:54 »
I've done a lot of lurking around GeekHack, but not too much posting... so let's work on changing that with this!
I've been dabbling around with keyboard designs over the past 10 months. Originally starting as an experiment to see what could be possible (and to learn a few more tricks), I've since worked up a couple of different designs. My first design was something for myself that I ended up offering as a handwired kits to those interested.
What I'm posting about now is my second design... a 40% board that's fairly simple: 3D printed bottom case and plate. Since everything I've learned about firmware building and case design has been made possible by open source designs and the community at-large, I figured it would be a good setup to post this design as a free-to-build option. If you can print the parts and get the hardware, have a blast!
I ended up calling this board "Ultimate Question" "Deep Thought"  with a few contributing factors:
- 42 keys
- I made this design out of being deathly curious to try a 40% design
- I really wanted to lean in to a joke with the number 42
- Before (and after) typing on this, I ask myself how someone can use a 40 keeb as a daily driver
If anyone is interested in building an Ultimate Question Deep Thought for themselves check out the following links!
Ultimate Question Deep Thought main page: https://clack-attack.com/deepthought/
Ultimate Question Deep Thought STL files: https://www.printables.com/model/224067-clack-attack-deep-thought
Ultimate Question Deep Thought GitHub repository: https://github.com/bishopj7/DeepThought
« Last Edit: Mon, 13 June 2022, 15:05:59 by bishopj7 »
Offline bishopj7
    • Clack-Attack
Re: I made an open source 40% Keeb
« Reply #1 on: Mon, 13 June 2022, 15:00:10 »
After sitting on the name for a few days, and getting a little bit of feedback - this project's name is being changed from "Ultimate Question" to "Deep Thought"
