Author Topic: Looking for a low profile tactile switch  (Read 12051 times)
Offline zmaster
« on: Mon, 13 June 2022, 14:43:51 »
Hello everyone,
I'm new to the hobby. A few months ago I bought a mechanical keyboard and replaced the switches with Boba U4T. I liked the tactility a lot, but I prefer a shorter travel. So, I'm looking for a "low profile" keyboard/switch. Unfortunately, there's much less choice compared to regular ones.
I bought a Nuphy Air75 and I wasn't satisfied with its Gateron browns.
I've been keeping an eye on the recently launched Logitech MX Mechanical, because I'd prefer a 100% ISO and it's a rarity. It comes with Kailh Choc V2 Browns for the tactile variant.
RTings just published their test results. Here's the comparison with the Air75:
https://www.rtings.com/keyboard/1-0/graph#33681/6685/31351
If I read the graph correctly, the Kailh is even less tactile than the Gateron. There's a drop of just 5gf compared to the 15gf of the Gateron.
Is my impression correct?
Any advice on alternatives is appreciated. I've seen the Banana/Mint switches from Keychron but I have not found any chart to compare them.
Re: Looking for a low profile tactile switch
« Reply #1 on: Mon, 13 June 2022, 15:44:05 »
Welcome to Geekhack!
Are you sure you mean "key travel"? That is how deep you can press a key, in total.
I believe the Boba U4T has slightly less key travel than the norm. You could try installing O-rings under the keycaps on the keyboard with Boba U4T and see if that makes any difference, and if you like it. Bottoming out would be much softer though.
Very broadly speaking, there are three main classes of "tactile" mechanical switches:
* Highly tactile, early bump: Boba U4T, Zealio V2, Holy Panda, ...
* Highly tactile, more rounded bump: Durock T1, Cherry MX Clear (scratchy and heavy), Zealio V1 (rare these days), ...
* Slightly tactile, tiny short bump: All "Brown" switches.
Brown switches are sometimes called "scratchy linear" by people who don't think they are tactile enough.. so you are not alone there. ;)
Offline Bozs
« Reply #2 on: Mon, 13 June 2022, 17:20:57 »
outemu low profile browns are a good alternative.  they have the same pin out as mx switches and the same keycap mount. the brown stems can also be swapped into the blue housings for added tactility, since outemu low profile blues use a " snap spring " instead of the traditional click jacket.. this spring can be lubed to reduce the click sound. so you end up with a short travel high tactile switch with gmk compatibility, and they are not limited to kailh chocolate pcb's  :thumb:
Offline zmaster
« Reply #3 on: Tue, 14 June 2022, 02:03:01 »
Yes, I was talking about key travel. I noticed that when I needed to type the same letter twice it was much easier on my old keyboard due to the shorter key travel.
I will consider the O-ring idea. The other problem I had with the Boba U4T is that they tended to "bind" when not pressed perfectly straight. I suspect they reduced the clearance between the stem and the housing to reduce the "wobble". This caused me to make significantly more typing mistakes compared to my membrane keyboard.
Thanks, I'll have a look. TBH, as a beginner I'm not eager to disassemble all switches one by one and mod them. But if the Outemu browns had a bit more tactility than Gateron they could be alright.
Offline Maledicted
« Reply #4 on: Mon, 20 June 2022, 14:34:38 »
How long did you use the Bobas before you decided you needed something with less travel? It is always a jarring experience if you switch between something like a chiclet keyboard and a more traditional iteration of a mechanical board. I literally could not type properly whenever I had to use other people's Macbooks just momentarily. This happens for me even if I switch between vastly different weightings and/or tactile events with similar travel.
I would give it a week and see if you acclimatize.
Never tried those. The blues are ... interesting. Better than MX clickies to my tastes, but not by a whole lot. What would you compare the browns to?
Offline zmaster
« Reply #5 on: Wed, 22 June 2022, 16:48:03 »
I used it for about a month, I figured that was enough to judge. In retrospect, I guess the binding was more annoying that the key travel.
Offline controller-works
    • Controller.works
« Reply #6 on: Wed, 13 July 2022, 21:24:34 »
I would recommend the Kailh Chocolate v1 switches. There are Browns with a medium force of 50g and Burnt Orange (corrected) with a heavy force of 70g. The travel is only 3mm. However, you must use these with a keyboard specifically designed for them.
Here is a video over of the v1 switches.
« Last Edit: Thu, 14 July 2022, 21:18:30 by controller-works »
« Reply #7 on: Wed, 13 July 2022, 23:56:15 »
The Kailh V1 Brown is not very tactile. This actual measured force graph shows only a small difference. Even full-size Cherry MX and Kailh Brown have a larger dip after the bump.
Kailh Choc Dark Yellow is a linear switch. Maybe you were thinking of the Kailh Choc Dark Orange - which has the same slider shape as the Brown but a stiffer spring. However,  same slider + stiffer spring ⇒ less tactile feel, as the force to overcome the tactile bump is smaller relative to the total force needed to press it.
« Last Edit: Thu, 14 July 2022, 00:05:07 by Findecanor »
    • Controller.works
« Reply #8 on: Thu, 14 July 2022, 21:19:32 »
Yes. You are right. We call the heavy tactile switches "Burnt Orange". I have corrected my post.
