Author Topic: IMB Model M died?  (Read 2321 times)
Offline GreyAmbience
  • I can stop when ever I want
IMB Model M died?
« on: Thu, 16 June 2022, 07:06:28 »
I was fixing up a Model M I found at work. It was working just fine, but then I accidentally plugged it into the green port on the USB adapter I have instead of the purple. It lit up and then died, and now nothing on it works. Is it just going in the trash now or can I save it?
Re: IMB Model M died?
« Reply #1 on: Thu, 16 June 2022, 07:09:06 »
False alarm! It was the cable on the board that has a loose connection! :D I am typing on it now, yai!
Offline Maledicted
« Reply #2 on: Mon, 20 June 2022, 14:22:45 »
I'm glad you figured that out. PS/2 isn't really meant to be hot-swappable either. You usually need the keyboard plugged into the correct port when the system POSTs for it to be functional when the operating system boots.
