Author Topic: Are there low-profile keycaps for realforce 87u?  (Read 7330 times)
Offline firegun9
« on: Sat, 18 June 2022, 23:55:05 »
I really like low-profile keycaps, such as the ones on Nuphy air75.
Instead of buying a air75, I was wondering maybe I can swap the keycaps on my realforce 87u for low-profile ones.
Is there such a thing?
Offline MIGHTY CHICKEN
Re: Are there low-profile keycaps for realforce 87u?
« Reply #1 on: Sun, 19 June 2022, 00:58:07 »
I've never seen low pro caps for topre exclusively, your best bet would be to convert one to mx stems then use normal "low" pro keycaps for MX on it
« Reply #2 on: Sun, 19 June 2022, 04:50:25 »
The Nuphy has low-profile key switches with low key travel, and the height of the keycaps is at least as high as the key travel + thickness of the plastic + curvature around the lowest point.
If it is the flat profile you're after. you could get a Topre keyboard with MX stems: A Realforce RGB or Novatouch, or one modded with after-market MX stems. Then populate it with same-height spherical keycaps such as DSA, XDA or MDA profile.
