Author Topic: TAC Works EVA inspired Zinc Alloy Novelty  (Read 11400 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Sun, 19 June 2022, 01:22:33 »
TAC WORKS ALL-METAL NOVELTY
SPEC
  • Zinc Alloy
  • Hand-painted and polished
  • Baking finish
  • close to Cherry Profile ESC Row
NOTE
  • Since the keycap is hand polishing, the corner and some edges are possible to be less polished or over-polished. However, the team is trying its best to improve the polishing technique.
  • Colour Differences. The keycap is hand-painted. The line part may be over-painted or colour-disconnected when polishing. It is a normal situation for hand-made keycaps. Moreover, the colour is man-mixed. Therefore, different baches of Keycaps are possible differences in colour.
[/color][/size]
BUY NOW
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: TAC Works EVA inspired Zinc Alloy Novelty
« Reply #1 on: Sun, 19 June 2022, 01:23:26 »
