Author Topic: [IC] Ciel65 - Gasket 65  (Read 34100 times)
Offline MIGHTY CHICKEN
« on: Sun, 19 June 2022, 11:18:19 »
GB post
Ciel65
Originally based off the Bakeneko by kkatano and now Ciel, Ciel65 is a 65% version of the Ciel.
Now with an external weight, in 6063, and PC
IC Form
Discord
Updates
Vendors finalised
Pricing added, GB date added
Colors finalized
Added ability to solder on rgb underglow
Swapped internal and external engravings so chicken will be on the inside and the Ciel cloud will be on the outside
Za Specs
  • Case:6063 Aluminum or PC with a through Brass Weight
  • Finish:Anodised or Frosted, Brass will be passivated
  • Typing Angle:6°
  • Mount:Gasket Gummy Worm O-Ring
  • PCB:QMK/VIA compatible, Multilayout Hotswap, Solder in extras
  • Plate:5052 Alu Plate anodised Silver, other options avail in extras, PC, FR4, Pom
  • Weight:1.1kg unbuilt, 1.6kg built
  • Kit:Case, Weight, 5052 Plate, 50a Oring, Custom Silicone Feet, JST and Daughterboard, All required hardware
  • Colors: Burgundy, Black, Silver, Lavender, Forest Green
Purchasing Info
  • Vendors
    • NA:ParamountKeeb
    • EU:Keygem
    • SEA/Asia:Mecha.Store
    • India:StacksKB
    • OCE:ALL CAPS
    • CA:AlphaKeys
  • Unlimited GB
  • Lead Time of 3~5 Months
  • GB Date
    August 12th - Septmeber 2nd
  • Starting price of $200 for aluminum, $210 for polycarbonate
Color Album
Layouts and Some Other Specs
Solder PCB with rgb underglow being worked on
Screw-In stabs supported
Renders and Prototype Pictures
Extended Album
Media
Saladknight Soundtest 1
Saladknight Soundtest 2
Nearlucid Review
« Last Edit: Sun, 21 August 2022, 22:29:09 by MIGHTY CHICKEN »
Offline nFaiz
Re: [IC] Ciel65 - Gasket 65
« Reply #1 on: Sun, 19 June 2022, 11:26:29 »
so lit
Offline misswaffle
« Reply #2 on: Sun, 19 June 2022, 11:28:14 »
That new engraving is gold. GLWIC!
Offline CGY
« Reply #3 on: Sun, 19 June 2022, 11:29:39 »
chickenman does it again
Offline LegendsWorks
  • thocc
« Reply #4 on: Sun, 19 June 2022, 11:36:48 »
so lit
Offline Fraaaan
« Reply #5 on: Sun, 19 June 2022, 11:45:11 »
Any interest in having ISO support this time?
Offline linell
« Reply #6 on: Sun, 19 June 2022, 11:54:47 »
this is the only engraving I'll need on a keyboard
bro this a **** set, just be thankful you even getting 1 base running fr
Offline Mena
« Reply #7 on: Sun, 19 June 2022, 12:11:16 »
Ciel so lit
Offline ankit
  • Formerly ankit-sachdeva
« Reply #8 on: Sun, 19 June 2022, 12:34:57 »
Please provide render with GMK cluck. Am not currently able to visualize the board correctly.
Offline superjackie
« Reply #9 on: Sun, 19 June 2022, 12:43:31 »
will there be WKL or exploded option?
Offline powwu
    • Discord
« Reply #10 on: Sun, 19 June 2022, 12:48:01 »
seal of approval. good job chickenman
thanks for waiting for fulfillment before starting a new project, shows you're galaxy brane
« Reply #11 on: Sun, 19 June 2022, 13:19:23 »
As of right now, no plans for exploded as it would require a two piece design, wkl would also split moqs up with all the colors
ok mr. ankit
Offline reaper2oc
« Reply #12 on: Sun, 19 June 2022, 13:54:51 »
So cool. Can we have the cloud design on the outside?  :-X and is the oring going going to be wrapped around the blocker?
Offline ALL CAPS
  • ALLCAPS
« Reply #13 on: Sun, 19 June 2022, 14:10:41 »
Yep, so keen. Count us interested.
« Reply #14 on: Sun, 19 June 2022, 14:24:40 »
It's been left up to vote, so far it seems like going with the original plan of taking off the chicken for the cloud.
There is an undercut so the oring is not stretched around a blocker
Offline Rilow
« Reply #15 on: Sun, 19 June 2022, 14:38:31 »
Will this support screw-in stabs?
Offline reaper2oc
« Reply #16 on: Sun, 19 June 2022, 14:49:11 »
YESSS. This is the portal, sequence, block67 killer I have been waiting for  ;D
« Reply #17 on: Sun, 19 June 2022, 16:03:54 »
It does
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #18 on: Sun, 19 June 2022, 16:14:35 »
No ISO support? Come on...
«How much wood could a woodchuck chuck if a woodchuck could chuck wood?»
Offline Akele
« Reply #19 on: Sun, 19 June 2022, 17:02:15 »
I'd like to see ISO support too.
Offline bitbot
« Reply #20 on: Sun, 19 June 2022, 21:42:17 »
0/10 no foam
Offline Rilow
« Reply #21 on: Sun, 19 June 2022, 23:59:50 »
It does
Awesome. Thank you. Cannonkeys' Bakeneko only supports clip-ins on some keys.
Offline plag
  • Formerly pepperonichicken
  • i also go by plag
« Reply #22 on: Mon, 20 June 2022, 07:21:46 »
It’s crazy how most of the world uses iso and there is no iso on this board
Offline Baka Bot
« Reply #23 on: Mon, 20 June 2022, 07:49:55 »
0/10 no foam
If you want foam so much then just buy it like everyone did b4 it was included in kits
Offline granola bar enthusiast
« Reply #24 on: Mon, 20 June 2022, 08:06:00 »
is there any plans in the future of a re-run of the Ciel60?
i think im just coping cus i missed the ciel60 run and i have too many 65's
« Last Edit: Mon, 20 June 2022, 08:21:15 by granola bar enthusiast »
Offline HappyB0T
  • I'm a Piggie
« Reply #25 on: Mon, 20 June 2022, 10:24:47 »
Pink + Chicken then I will buy.
Offline Lucasy
« Reply #26 on: Mon, 20 June 2022, 15:06:45 »
original approach
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #27 on: Mon, 20 June 2022, 15:39:07 »
Indeed. That's what I'm wondering too.
Offline DirtyGingy
« Reply #28 on: Mon, 20 June 2022, 16:01:39 »
Nice cock
Offline DeMechanica
« Reply #29 on: Mon, 20 June 2022, 17:15:57 »
Looks cool! But as I found on my Portal, an o-ring with a blocker completely messed up the o-ring typing feel, making it super inconsistent. I’d recommend removing the blocker if possible, or changing the mounting style. Good luck!
Offline bitbot
« Reply #30 on: Mon, 20 June 2022, 18:08:31 »
0/10 no foam
ab_channel=Sordiway
« Reply #31 on: Mon, 20 June 2022, 18:17:19 »
There is an undercut that removes the problem of oring being stretched
Offline conternecticus
« Reply #32 on: Mon, 20 June 2022, 22:47:45 »
Another way of solving that issue is making the blocker "float". Don't make it go all the way down to the bottom case.
Offline ankit
« Reply #33 on: Tue, 21 June 2022, 00:46:31 »
  • Target price of $200~210
Offline totalemon
  • good morning :)
« Reply #34 on: Tue, 21 June 2022, 20:08:00 »
awful cock
Offline HappyB0T
  • I'm a Piggie
« Reply #35 on: Tue, 21 June 2022, 21:48:31 »
I want a chicken on my keyboard. I'm in.
« Reply #36 on: Wed, 22 June 2022, 23:31:41 »
Added some vendors
Offline chaitues
« Reply #37 on: Thu, 23 June 2022, 02:01:11 »
Will you consider something without the chicken engraving?
Offline KBKlon
« Reply #38 on: Sat, 25 June 2022, 08:04:15 »
+1 for other engraving options besides the long chicken pls.
Offline bitbot
« Reply #39 on: Sat, 25 June 2022, 17:57:30 »
no, force the cock on the engraving
Offline treeleaf64
    • treeleaf64
« Reply #40 on: Sun, 26 June 2022, 11:30:18 »
Chicken   Hello  Chicken
Everyone must pay the cat tax
Offline ocean.setups
« Reply #41 on: Mon, 27 June 2022, 11:38:48 »
The cloud weight engraving looks pretty nice! Would keep that instead of the chicken :D
« Reply #42 on: Sun, 17 July 2022, 21:17:00 »
https://youtu.be/zeLezjxrnhA
« Reply #43 on: Fri, 22 July 2022, 16:27:05 »
all vendors added, tested proto pcb, waiting for some rgb strips, currently planning 1st or 2nd week of august for gb
Ankit will be streaming a build soon,
also vid by near lucid
« Last Edit: Fri, 22 July 2022, 16:29:00 by MIGHTY CHICKEN »
