Author Topic: [IC] IQUNIX Q66 Custom Mechanical Keyboard  (Read 4692 times)
Offline Kelley Kenny
« on: Sun, 19 June 2022, 21:28:38 »
Link:https://iqunix.store/collections/interest-check/products/iqunix-q66-mechanical-keyboard
Layout: 60%
Keys: 66
Materials: Aluminum Case + PBT Keycaps
PCB: Hot-Swappable PCB
Connection: Wired USB-C
Larger Key Structure: Cherry Style Stabilizers(Screw-In)
Keycap Profile: Cherry Style
Keycap Printing: Dye Sublimation
Switch Orientation: South-facing
QMK/VIA Support
« Last Edit: Mon, 20 June 2022, 01:13:06 by Kelley Kenny »
Offline TekNiq
Re: [IC] IQUNIX Q66 Custom Mechanical Keyboard
« Reply #1 on: Mon, 20 June 2022, 20:32:11 »
Might help to explain the rationale behind the design choice to have a wider signature towards the bottom of the board.
Offline LaminarDesigns
  • General crackhead
« Reply #2 on: Mon, 20 June 2022, 20:45:20 »
Not a single ounce of useful information was posted.
Offline Lee ag
« Reply #3 on: Tue, 21 June 2022, 02:33:03 »
COME ON
Offline Backspace2
  • Third most used key on the keyboard is Backspace!
« Reply #4 on: Tue, 21 June 2022, 10:05:14 »
Wow.  :blank:
Yes
