Author Topic: Switch blocker  (Read 4036 times)
Offline phinix
Switch blocker
« on: Fri, 24 June 2022, 18:04:20 »
I may have seen this kind of subject before, but need to ask anyway.
Where could I get a switch blocker?
I've seen those from SP and some others in the past.
But I need one that would be nicely fit - for example in kbd67lite to cover one cap above arrows.
Offline Auxo
  • Formerly CJD_Anthony
Re: Switch blocker
« Reply #1 on: Fri, 24 June 2022, 22:21:18 »
https://pimpmykeyboard.com/switch-blocker-pack-of-10/
Here you go, not sure if this will fit your needs aesthetically, but its an option
Alternatively, there are these as well:
https://kbdfans.com/products/5-case-aluminium-blockers
« Last Edit: Fri, 24 June 2022, 22:22:57 by Auxo »
